jQuery UI Widgets Forums General Discussions Navigation Tree My treeview does not show up using getRecordsHeirarchy
This topic contains 2 replies, has 2 voices, and was last updated by  bobsov 11 years, 9 months ago.
  • bobsov
    “name1”: “4481”,
    “name2”: “AH1RS”,
    “name3”: “DISP”
    “name1”: “M4487A”,
    “name2”: “AH7”,
    “name3”: “HSP14 SETBK”
    “name1”: “M4487A”,
    “name2”: “AH7”,
    “name3”: “CSP16 SETBK”
    “name1”: “M4487A”,
    “name2”: “AH7”,
    “name3”: “HSP16 SETBK”
    var records = dataAdapter.getRecordsHierarchy(‘name1’, ‘name2’, null, [{ name: ‘name1’, map: ‘label’}]);
    I would like to make name1 my id field and name2 my parentId field. But this does not work. I am getting null for “records”. Do id and parentId always have to be integers?
    Hello bobsov,
    Id and parentid can be any string. However, they cannot be mapped to another datafield and should always be called “id” and “parentid”. Here is an example:
    <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script>
    <body>
    <div id='content'>
    var theme = "";
    var data = [
    "id": "4481",
    "parentid": "-1",
    "name3": "DISP"
    "id": "M4487A",
    "parentid": "4481",
    "name3": "HSP14 SETBK"
    "id": "M4487B",
    "parentid": "4481",
    "name3": "CSP16 SETBK"
    "id": "M4487C",
    "parentid": "M4487A",
    "name3": "HSP16 SETBK"
    { name: 'id' },
    { name: 'parentid' },
    { name: 'name3' }
    localdata: data
    // create data adapter.
    // perform Data Binding.
    dataAdapter.dataBind();
    // get the tree items. The first parameter is the item's id. The second parameter is the parent item's id. The 'items' parameter represents
    // the sub items collection name. Each jqxTree item has a 'label' property, but in the JSON data, we have a 'text' field. The last parameter
    // specifies the mapping between the 'text' and 'label' fields.
    var records = dataAdapter.getRecordsHierarchy('id', 'parentid', 'items', [{ name: 'name3', map: 'label'}]);
    $('#jqxWidget').jqxTree({ source: records, width: '300px', theme: theme });
    <div id='jqxWidget'>
    bobsov
    Never thought of that. That may solve my issue. I am loving it.
