jQuery UI Widgets Forums General Discussions Lists DropDownList DropdownList inside window
This topic contains 2 replies, has 2 voices, and was last updated by  gush 10 years, 3 months ago.
  • DropdownList inside window #83019
    gush
    I’m using jqxDropDownList inside a jqxWindow.
    I’m catching the close event for the window, and calling ‘destroy’ to clean the DOM.
    The problem is that the dropdownlist is leaving behind a top level div.
    Is there anything I can do to clean it up when the window is closed?
    DropdownList inside window #83026
    Hello gush,
    Try to use this way:
    $('#jqxWindow').on('close', function (event) {
        $('#jqxDropDownList').jqxDropDownList('destroy');
        $("#jqxWindow").jqxWindow('destroy');
    DropdownList inside window #83028
    gush
    Hi Hristo,
    That worked perfectly. Thank you.
