jQuery UI Widgets Forums Navigation Tree Drag&Drop in iframe = XSS problem
This topic contains 2 replies, has 2 voices, and was last updated by  ashensugar 11 years, 4 months ago.
  • Drag&Drop in iframe = XSS problem #48016
    ashensugar
    Hi everyone, I’m using a JqxTree with drag&drop functionnality, and my tree is wrapped inside a JqxWindow.
    Everything works fine until I launch the page from a different domain inside an iframe.
    Classic ajax using works well inside the iframe (i can do $.get(…) or $.post(…) without any problem, and my JqxGrid works fine too).
    Databinding my jqxTree (with drag&drop) throws an error in any navigator:
    Error: Permission denied to access property ‘document’ (Firefox)
    This error comes from jqxdragdrop on column around n°3800 :
    if(window.top.document.addEventListener){window.top.document.addEventListener("mouseup",c,false)}else{if(window.top.document.attachEvent){window.top.document.attachEvent("onmouseup",c)}
    This portion of code tries to access window.top.document property, which we can’t reach because of xss protection of navigators i think.
    Sorry to cause trouble ^^ but I searched a lot and can’t find anyone with the same problem.
    What do you think about that ? did you notice it already ? can we eventually modify dragdrop.js to fit in an iframe of different domain without problem ?
    Any advice would be greatly appreciated.
    Drag&Drop in iframe = XSS problem #48142
    Hello ashensugar,
    Thank you for your feedback. We will fix the reported issue as soon as possible.
    Drag&Drop in iframe = XSS problem #48151
    ashensugar
    Hello Dimitar,
    Happy if i can help. Thanks for the reply.
    Have a nice day ! 🙂
