jQuery UI Widgets › Forums › General Discussions › Dialogs and Notifications › Window › Window height problem if initContent is used
Tagged: height, initContent, initialize, jqxwindow, size, Widget, window
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 10 years, 10 months ago.
The height of the window is not set correctly if jqxInput widgets are initialized within initContent of jqxWindow. If you move the code, within initContent, before the creation of jqxWindow everything is fine.
It looks to me a bug, because the purpose of the initContent, according to documentation, is to initialize other widgets.
Here is an example code:
<!DOCTYPE html> <html> <head> <title></title> <meta http-equiv="content-type" content="text/html;charset=utf-8" /> <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" /> <link rel="stylesheet" href="jqwidgets/styles/jqx.energyblue.css" type="text/css" /> <script type="text/javascript" src="scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="jqwidgets/jqxwindow.js"></script> <script type="text/javascript" src="jqwidgets/jqxinput.js"></script> <script type="text/javascript"> $(document).ready(function () { $('#dialog').jqxWindow({ theme: "energyblue", isModal: true, closeButtonAction: 'close', width: 360, initContent: function() { $('input').jqxInput({ theme: "energyblue", width: 250, height: 18 }); } }); }); </script> </head> <body> <div id="dialog"> <div>Test Me</div> <div> <input type="text" name="email1" id="email1" /><br/> <input type="text" name="email2" id="email2" /><br/> <input type="text" name="email3" id="email3" /><br/> <input type="text" name="email4" id="email4" /><br/> <input type="text" name="email5" id="email5" /><br/> <input type="text" name="email6" id="email6" /><br/> <input type="text" name="email7" id="email7" /><br/> <input type="text" name="email8" id="email8" /><br/> <input type="text" name="email9" id="email9" /><br/> </div> </div> </body> </html>
Hello rhorvath,
In the case with initContent, the window is automatically sized based on the height of the un-initialized inputs. This is a normal behaviour, because the window’s height is adjusted before initContent is called.
