jQuery UI Widgets Forums Grid what is the problem
This topic contains 2 replies, has 2 voices, and was last updated by  Dimitar 11 years, 5 months ago.
  • what is the problem #46158
    okasha
    hello jqwidgets Guys
    may you please help me find the problem with that simple code
    <html lang=”en”>
    <meta charset=”utf-8″>
    <title>Welcome to CodeIgniter</title>
    <link rel=”stylesheet” href=”<?= base_url(); ?>js/jqwidgets/styles/jqx.base.css” type=”text/css” />
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jquery-2.0.3.min.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxdata.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxmenu.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxgrid.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxgrid.sort.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxgrid.filter.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxlistbox.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxcheckbox.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxwindow.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxinput.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxdropdownlist.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxgrid.selection.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxgrid.pager.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/jqwidgets/jqxgrid.edit.js”></script>
    <script type=”text/javascript” src=”<?= base_url(); ?>js/scripts/gettheme.js”></script>
    //var data = {};
    var theme = ‘classic’;
    { name: ‘EmployeeID’ },
    { name: ‘FirstName’ },
    { name: ‘LastName’ },
    { name: ‘Title’ },
    { name: ‘Address’ },
    { name: ‘City’ },
    { name: ‘Country’ },
    {name: ‘Edit’} ],
    url: ‘http://localhost/test/index.php/welcome/display’,
    root: ‘Rows’,
    /* var data = “update=true&FirstName=” + rowdata.FirstName + “&LastName=” + rowdata.LastName + “&Title=” + rowdata.Title;
    data = data + “&Address=” + rowdata.Address + “&City=” + rowdata.City + “&Country=” + rowdata.Country + “&Notes=””;
    data = data + “&EmployeeID=” + rowdata.EmployeeID;
    dataType: ‘json’,
    data: data,
    commit(true);
    error: function () {
    commit(false);
    alert(“update”);
    var dataadapter = new $.jqx.dataAdapter(source);
    // initialize jqxGrid
    $(“#jqxgrid”).jqxGrid(
    width: 1300,
    rtl:true,
    selectionmode: ‘checkbox’,
    source: dataadapter,
    //editable: true,
    virtualmode: true,
    rendergridrows: function () {
    return dataadapter.records;
    { text: ‘EmployeeID’, datafield: ‘EmployeeID’, width: 100 },
    { text: ‘First Name’, datafield: ‘FirstName’, width: 100 },
    { text: ‘Last Name’, datafield: ‘LastName’, width: 100 },
    { text: ‘Title’, datafield: ‘Title’, width: 180 },
    { text: ‘Address’, datafield: ‘Address’, width: 180 },
    { text: ‘City’, datafield: ‘City’, width: 100 },
    { text: ‘Country’, datafield: ‘Country’, width: 140 },
    { text:’Edit’,width:80,columntype:”button”, cellsrenderer: function () {
    return “تعديل”;
    editrowindex = row;
    var id = $(“#jqxgrid”).jqxGrid(‘getcellvalue’, row, “EmployeeID”);
    $(“#jqxwindow”).jqxWindow({ width: 400, height: 300,rtl:true });
    $(“#first_name”).jqxInput({ width: ‘250px’, height: ’25px’});
    $(“#cancel”).jqxButton({ width: ‘100’, height: ’25’});
    $(“#update”).jqxButton({ width: ‘100’, height: ’25’});
    $(“#first_name”).val($(“#jqxgrid”).jqxGrid(‘getcellvalue’, row, “FirstName”));
    $(‘#cancel’).on(‘click’, function () { $(“#jqxwindow”).jqxWindow(“close”);
    $(“#jqxwindow”).jqxWindow(“show”);
    $(‘#update’).bind(‘click’, function () {
    var selectedrowindex = $(“#jqxgrid”).jqxGrid(‘getselectedrowindex’);
    var id = $(“#jqxgrid”).jqxGrid(‘getrowid’, selectedrowindex);
    var rowdata={};
    //rowdata[“FirstName”]=”mohamed”;
    $(“#jqxgrid”).jqxGrid(‘updaterow’, id, rowdata);
    //alert(“klkk”);
    <body class=’default’>
    <!– <input style=”float:right;” type=”text” name=”cust_name” id=”cust_name” size=”50″ > –>
    <div style=”clear:both;”></div>
    <div style=”float:right;” id=”jqxgrid”>
    <div style=”display:none;” id=’jqxwindow’>
    <div id=”header”></div>
    <div id=”content”>
    <input type=”text” name=”first_name” id=”first_name” >
    <input type=”button” value=”تحديث” id=”update” >
    <input type=”button” value=”الغاء” id=”cancel” >
    it should alert “update” when i click “تحديث”
    thanks for your help in advance
    what is the problem #46350
    okasha
    can anyone help please
    what is the problem #46382
    Hello okasha,
    Everything seems fine in your code. Please make sure you are using the latest version of jQWidgets (3.0.4).
