jQuery UI Widgets Forums Chart Chart
This topic contains 2 replies, has 2 voices, and was last updated by  Dimitar 9 years, 10 months ago.
    Chart Posts
  • Chart #76335
    anubis76
    Dear Team,
    I am facing a strange issue whereby the first time I load my chart (by right-clicking a cell in my jqxGrid), the Chart loads very quickly (less than 500ms). However, from the second time onwards, the same chart takes extremely long to load again (sometimes greater than 8 seconds). What could be the possible cause for this and is there any workaround?
    AJ
    Chart #76336
    anubis76
    Could not edit my previous post….
    I am using jqWidgets 3.7.0
    Chart #76359
    Hello anubis76,
    Please make sure that from the second time onwards you do not try to reinitialize the chart, but only update what is necessary, e.g. the loaded data or some of the chart’s properties. We also recommend updating to the latest version of jQWidgets (3.8.2) for the best widget experience.
    If neither of these suggestions help, please share an example demonstrating the issue with us.
