jQuery UI Widgets Forums General Discussions Navigation Tabs Using jqxTooltip with Tabs
This topic contains 2 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 2 months ago.
  • Using jqxTooltip with Tabs #20402
    Charlie
    I’m trying to get Tooltips to work with tabs:-
    http://www.podsmeadbiglocal.co.uk/residents/views.php
    The tips work on the rest of the links but not the tab titles, what am I missing?
    Charlie
    Using jqxTooltip with Tabs #20548
    Charlie
    Any help with this?
    Using jqxTooltip with Tabs #20597
    Please, find a working sample below:
    <meta name="keywords" content="jQuery Tabs, Tabs Widget, TabView, jqxTabs" />
    <meta name="description" content="The jqxTabs is breaking the content into multiple sections. You
    can populate it from 'UL' for the tab titles and 'DIV' for it's contents." />
    <title id='Description'>The jqxTabs is breaking the content into multiple sections.
    You can populate it from 'UL' for the tab titles and 'DIV' for it's contents.
    </title>
    <script type="text/javascript" src="../../jqwidgets/jqxtooltip.js"></script>
    var theme = getDemoTheme();
    // Create jqxTabs.
    $('#jqxTabs').jqxTabs({ width: '90%', height: 200, position: 'top', theme: theme });
    var elements = $("#jqxTabs").find('ul:first').children();
    $.each(elements, function(index, value)
    $(this).jqxTooltip({content: $(this).text()});
    <div id='jqxWidget'>
    <div id='jqxTabs'>
    <ul>
    <li style="margin-left: 30px;">Node.js</li>
    <li>JavaServer Pages</li>
    <li>Active Server Pages</li>
    <li>Python</li>
    <li>Perl</li>
    </ul>
    <div>
    Node.js is an event-driven I/O server-side JavaScript environment based on V8. It
    is intended for writing scalable network programs such as web servers. It was created
    by Ryan Dahl in 2009, and its growth is sponsored by Joyent, which employs Dahl.
    Similar environments written in other programming languages include Twisted for
    Python, Perl Object Environment for Perl, libevent for C and EventMachine for Ruby.
    Unlike most JavaScript, it is not executed in a web browser, but is instead a form
    of server-side JavaScript. Node.js implements some CommonJS specifications. Node.js
    includes a REPL environment for interactive testing.
    <div>
    JavaServer Pages (JSP) is a Java technology that helps software developers serve
    dynamically generated web pages based on HTML, XML, or other document types. Released
    in 1999 as Sun's answer to ASP and PHP,[citation needed] JSP was designed to address
    the perception that the Java programming environment didn't provide developers with
    enough support for the Web. To deploy and run, a compatible web server with servlet
    container is required. The Java Servlet and the JavaServer Pages (JSP) specifications
    from Sun Microsystems and the JCP (Java Community Process) must both be met by the
    container.
    <div>
    ASP.NET is a web application framework developed and marketed by Microsoft to allow
    programmers to build dynamic web sites, web applications and web services. It was
    first released in January 2002 with version 1.0 of the .NET Framework, and is the
    successor to Microsoft's Active Server Pages (ASP) technology. ASP.NET is built
    on the Common Language Runtime (CLR), allowing programmers to write ASP.NET code
    using any supported .NET language. The ASP.NET SOAP extension framework allows ASP.NET
    components to process SOAP messages.
    <div>
    Python is a general-purpose, high-level programming language[5] whose design philosophy
    emphasizes code readability. Python claims to "[combine] remarkable power with very
    clear syntax",[7] and its standard library is large and comprehensive. Its use of
    indentation for block delimiters is unique among popular programming languages.
    Python supports multiple programming paradigms, primarily but not limited to object-oriented,
    imperative and, to a lesser extent, functional programming styles. It features a
    fully dynamic type system and automatic memory management, similar to that of Scheme,
    Ruby, Perl, and Tcl. Like other dynamic languages, Python is often used as a scripting
    language, but is also used in a wide range of non-scripting contexts.
    <div>
    Perl is a high-level, general-purpose, interpreted, dynamic programming language.
    Perl was originally developed by Larry Wall in 1987 as a general-purpose Unix scripting
    language to make report processing easier. Since then, it has undergone many changes
    and revisions and become widely popular amongst programmers. Larry Wall continues
    to oversee development of the core language, and its upcoming version, Perl 6. Perl
    borrows features from other programming languages including C, shell scripting (sh),
    AWK, and sed.[5] The language provides powerful text processing facilities without
    the arbitrary data length limits of many contemporary Unix tools, facilitating easy
    manipulation of text files.
    </div
    <div id='settings'>
    <div id='animation'>
    Enable Select Animation</div>
    <div id='contentAnimation'>
    Enable Content Animation</div>
