jQuery UI Widgets › Forums › TreeGrid › Triggering rowDetailsRenderer on Click of Row
Tagged: addrow, angular treegrid, angular2 treegrid, bootstrap treegrid, javascript treegrid, jquery treegrid, jqwidgets treegrid, jqxTreeGrid, New row, rowDetailsRenderer
This topic contains 5 replies, has 2 voices, and was last updated by Hristo 8 years, 9 months ago.
I have a grid and each row has associated row details. I want these details to be hidden and loaded via AJAX on click of the row. (I can handle that code and don’t need help with that).
I have the code that triggers when clicked:
$('#treeGrid').on('rowSelect', function (event) { // etcHow can I render the row details for a row when clicked? If this isn’t possible, how can I append a row beneath the current row? AddRow seems to only add rows to the top or bottom of the Table.
I can provide additional information or code if need be, but any push to the right direction will be enough. Thanks!
Hello jacobraccuia,
Unfortunately, there is no such option. I would like to suggest you look at “Nested Grids”, “Row Details” (jqxGrid) and “Nested Tables” (jqxDataTable) as an eventual alternative.
Yes, it is possible – you could add a new row as a child to another item with
addRowmethod.
Please, take a look at this example:var parentID = 8; $("#treeGrid").jqxTreeGrid('addRow', null, { FirstName: "Name", LastName: "Last Name" }, 'first', parentID);Thank you for your understanding.
Hristo HristovjQWidgets team
http://www.jqwidgets.comI wish I saw this earlier! I was waiting for an email.
Thanks so much for replying back to me! I did not think about adding a row to the child and that is a great idea. I will let you know if this works for me 🙂
Actually – I have a question. I am ultimately trying to load a second Tree Grid inside of this one, on click. Is it possible to have a new child row with only one (unique) column?
Hello jacobraccuia,
Unfortunately, it is not possible.
It is possible to useaggregatesRenderercallback member for this requirement, you could try it.
Please, take a look at this demo as a base:
http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxtreegrid/javascript-tree-grid-manual-aggregates-calculation.htm?light
Could you give more details what you want to achieve and I can give you a better a solution?Best Regards,
http://www.jqwidgets.comWhat you showed me is really cool!
So I have a tree grid hierarchy of Accounts, and when you click on an Account, ideally, its details slide open (or new row) and inside this row there is a new grid with a list of Contacts associated with the account. The columns are all unique.
I’m using a regular grid to display the contacts, and I currently have the contacts for the grid loading on click of the row, but the grid is beneath the treegrid.
I am thinking that my solution will probably be to load the second grid in a modal window. It might also provide a better UX anyways.
thank you for your help,
Jacob
Hello jacobraccuia,
The solution with modal Grid is a good approach as you mention.
I would suggest you to think if it is possible to use some of the previous examples.
Also, I would like to suggest you one more example: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/dropdowngrid.htm?light
(that could try to add to aggregates fields)Best Regards,
