jQuery UI Widgets Forums TreeGrid TreeGrid reorder
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 8 years ago.
  • TreeGrid reorder #93731
    piyush.sharma0009
    I am facing a problem in dragging the Columns and Reordering on The Surface Pro Device on Edge Browser : The reordering of Columns is not possible. Although the reordering is working with the Mouse but the problem exists with the Touch.
    Can you please identify and propose the solution?
    Piyush Sharma
    TreeGrid reorder #93734
    Hi Piyush Sharma,
    It is not possible to reorder columns on touch. The widget adapts itself to the device, but of course some of the more advanced features will not be able to be used as they are for desktop only.
