jQuery UI Widgets Forums Chart stacked column chart negative values
This topic contains 1 reply, has 2 voices, and was last updated by  Christopher 9 years, 11 months ago.
  • stacked column chart negative values #86207
    atomic
    Hi guys,
    My jqx stacked chart is not displaying negative values. Any ideas?
    thnaks
    chart.jqxChart({
    					title: '',
    					//description: final_energy_demand_fuel_shares + ' ' + sector,
    					description: 'el. mix shares',
    					enableAnimations: true,
    					showLegend: true,
    					source: nestedAdapterChart,
    					categoryAxis:
    							text: 'Category Axis',
    							type: 'basic',
    							textRotationAngle: 0,
    							dataField: 'phase',
    							showTickMarks: true,
    							tickMarksInterval: 1,
    							tickMarksColor: '#888888',
    							unitInterval: 1,
    							showGridLines: false,
    							gridLinesInterval: 1,
    							gridLinesColor: '#888888',
    							axisSize: 'auto'
    					colorScheme: 'scheme01',
    					seriesGroups:
    								type: 'stackedcolumn',
    								columnsGapPercent: 100,
    								//seriesGapPercent: 10,
    								valueAxis:
    									unitInterval: 20,
    									minValue: -100,
    									maxValue: 100,
    									displayValueAxis: true,
    									description: '%',
    									axisSize: 'auto',
    								series: [
    	                            		{ dataField: 'Coal', displayText: coal, color: clCoal},
    	                            		{ dataField: 'Oil', displayText: oil, color: clOil},
       	                                    { dataField: 'Hydro', displayText: hydro, color: clHydro},
    	                            		{ dataField: 'Gas', displayText: gas, color: clGas},
    	                                    { dataField: 'Biofuels', displayText: biofuels, color: clBiofuels},
    	                            		{ dataField: 'Solar', displayText: solar, color: clSolar},
    	                                    { dataField: 'Peat', displayText: peat, color: clPeat},
    	                                    { dataField: 'Waste', displayText: waste, color: clWaste},
    	                                    { dataField: 'Oil_shale', displayText: oil_shale, color: clOil_shale},
                                            { dataField: 'Wind', displayText: wind, color: clWind},
                                            { dataField: 'Geothermal', displayText: geothermal, color: clGeothermal},
                                            { dataField: 'Nuclear', displayText: nuclear, color: clNuclear},
                                            { dataField: 'UD', displayText: ud, color: '#ff0000'},
                                            { dataField: 'importexport', displayText: importexport, color: '#0000ff'}
    								//	series: series_fuels
    stacked column chart negative values #86216
    Christopher
    Hi atomic,
    We tested your code with other data source and the jqxChart displays negative values. So your code is correct. Check your data if it actually contains negative values that should be displayed. Here is a demo of your code working with our data source:
    https://www.jseditor.io/?key=xb-chart-1
    Christopher
