jQuery UI Widgets Forums Layouts Splitter Splitter Panel width | Unit issue
This topic contains 2 replies, has 2 voices, and was last updated by  raj 9 years, 7 months ago.
  • Splitter Panel width | Unit issue #78565
    raj
    When I try to get the panel size it is returning in percentage(%) not in pixels? How to get the panel size in pixels?
    <div id='jqxSplitter'>
        <div style="background-color: #97FFAF"></div>
        <div style="background-color: #E8C0AF"></div>
    <input type="button" id="getPanelSize" value="Panels Size" />
    $("#jqxSplitter").jqxSplitter({
        width: '100%',
        height: '300px',
        theme: 'energyblue',
        panels: [{ size: "42%", min:180, collapsible:false }, { size: '58%'}]
    $("#getPanelSize").click(function(){
    var panels = $("#jqxSplitter").jqxSplitter("panels");
        alert(panels[0].size)
    Can someone suggest me a solution?
    Raj
    Splitter Panel width | Unit issue #78569
    ivailo
    Hi raj,
    If you set values in percentage – you will get values in percentage.
    So try to use values in pixels.
    Also as an workaround you can use .width() method about your panels and it will return values in pixels.
    Ivailo Ivanov
    Splitter Panel width | Unit issue #78572
    raj
    Hi Ivailo,
    Thanks for your quick turnaround. It worked perfect 🙂
    Regrads,
    Raj
