jQuery UI Widgets Forums Navigation Tree Sorting inside a parent element
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 1 month ago.
  • Sorting inside a parent element #21807
    kabil
    Hello everyone,
    I want to add sorting algoirthm intto my jq tree plugin.
    I know how to do it but i could not make it work.
    on dragEnd event, draggedItem‘s parentElement has to be the dropItem (item has to be dropped into it’s parent item).
    Ex : item.element.parentElement == dropItem.element (dont know if it works)
    if true, i’ll get first level child items of dropItem in a loop and send my server side to sort them.
    Thanks.
    Sorting inside a parent element #21879
    1. That depends on when the event is raised and which is the parentElement when you drop the item.
    2. Sorting in jqxTree is currently not supported.
