jQuery UI Widgets › Forums › Chart › setting series colorScheme for stackedcolumn chart
Tagged: chart, colorScheme, javascript chart, jquery chart, jqwidgets chart, stackedcolumn
This topic contains 6 replies, has 2 voices, and was last updated by aykutucar 8 years, 3 months ago.
I am trying to have a stackedcolumn chart with 2 series using different color schemes.
I tried to do something like below but it ignores the colorScheme.
When I try to to set the color scheme after the line type: ‘stackedcolumn’, I get seriesIndex is not defined error.
I also tried to set the fillcolor for each series which kinda works but this time I lose mouseover highlighting and the gradient even though I set useGradient to true.seriesGroups:
columnsGapPercent:12,
seriesGapPercent: 0,
series: [
dataField: ‘DMEK’, displayText: ‘DMEK’, colorScheme: ‘scheme02’
dataField: ‘DSAEK’, displayText: ‘DSAEK’, colorScheme: ‘scheme02’
dataField: ‘PKP’, displayText: ‘PKP’, colorScheme: ‘scheme02’
dataField: ‘Other’, displayText: ‘Other’, colorScheme: ‘scheme02’
columnsGapPercent: 15,
series: [
dataField: ‘Domestic’, displayText: ‘Domestic’, colorScheme: ‘scheme09’
dataField: ‘International’, displayText: ‘International’, colorScheme: ‘scheme09’
]Hello aykutucar,
You should use
color
member of the particular column of the series.
Please, take a look the example below, it is based on “Stacked and Grouped Column Series” demo:<!DOCTYPE html> <html lang="en"> <head> <title id='Description'>JavaScript Chart Stacked and Grouped Series example</title> <meta name="description" content="This is an example of JavaScript Chart Stacked and Grouped Series." /> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdraw.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxchart.core.js"></script> <script type="text/javascript"> $(document).ready(function () { // prepare chart data as an array var sampleData = [ { Day: 'Monday', Running: 30, Swimming: 5, Cycling: 25, Riding: 10 }, { Day: 'Tuesday', Running: 25, Swimming: 25, Cycling: 0, Riding: 15 }, { Day: 'Wednesday', Running: 30, Swimming: 5, Cycling: 25, Riding: 25 }, { Day: 'Thursday', Running: 35, Swimming: 25, Cycling: 45, Riding: 15 }, { Day: 'Friday', Running: 5, Swimming: 20, Cycling: 25, Riding: 5 }, { Day: 'Saturday', Running: 30, Swimming: 0, Cycling: 30, Riding: 30 }, { Day: 'Sunday', Running: 60, Swimming: 45, Cycling: 5, Riding: 20 } ]; // prepare jqxChart settings var settings = { title: "Fitness & exercise weekly scorecard", description: "Time spent in vigorous exercise by activity", enableAnimations: true, showLegend: true, padding: { left: 5, top: 5, right: 5, bottom: 5 }, titlePadding: { left: 90, top: 0, right: 0, bottom: 10 }, source: sampleData, colorScheme: 'scheme06', xAxis: { dataField: 'Day', unitInterval: 1, tickMarks: { visible: true, unitInterval: 1, color: '#888888' }, gridLines: { visible: false, unitInterval: 1, color: '#888888' } }, valueAxis: { unitInterval: 10, minValue: 0, maxValue: 120, visible: true, title: { text: 'Time in minutes<br>' }, tickMarks: { color: '#888888' }, gridLines: { color: '#888888' } }, seriesGroups: [ { type: 'stackedcolumn', columnsGapPercent: 50, seriesGapPercent: 5, series: [ { dataField: 'Running', displayText: 'Running', color: "#FF0000" }, { dataField: 'Swimming', displayText: 'Swimming', color: "#00FF00" } ] }, { type: 'stackedcolumn', columnsGapPercent: 50, seriesGapPercent: 5, series: [ { dataField: 'Riding', displayText: 'Riding' }, { dataField: 'Cycling', displayText: 'Cycling' } ] } ] }; // setup the chart $('#chartContainer').jqxChart(settings); }); </script> </head> <body class='default'> <div id='chartContainer' style="width: 850px; height: 500px;"></div> <div class="example-description"> <br /> <h2>Description</h2> <br /> This is an example of JavaScript chart stacked and grouped series. </div> </body> </html>
Hristo HristovjQWidgets team
http://www.jqwidgets.comHi Hristo,
It does the same thing as fillColor.
And again, I lose the mouseover highlighting and the gradient even though I set useGradient to true.
Is there a way to draw the color with the gradient?
Thanks.Hello aykutucar,
I tested again this example and it seems to work fine.
Maybe these colors are too saturated and they confusing.
I would like to suggest you try with more ‘soft’ colors (eg. “#798ba8” & “#d1a151”).Best Regards,
http://www.jqwidgets.comHi again,
I don’t think it is related to the color.
I modified a previous fiddle of yours and changed one of the series to blue.
You can see that there is no gradient and no mouseover highlighting.Hello aykutucar,
Thank you for this feedback.
I recommend you to usefillColor
(because “color” property is deprecated) and hexadecimal color representation (“#0000FF”).
Please, take a look at this example.Best Regards,
That fixed it, thank you so much for your help. -
