jQuery UI Widgets Forums Navigation Tree Scrolling Issue when DropDownTree isn't wide enough
This topic contains 2 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 6 months ago.
  • psteele
    I have an issue with the DropDownTree. If the contents of the treeview that drops down is not big enough to handle the size of the content, a horizontal scrollbar will appear (as expected). However, the scrollbar appears as soon as the page loads — before the dropdown has even been dropped.
    And as you click on the body of the web page, there’s a “phantom” close animation happening for the tree div. You can see what I’m talking about by editing the demo “dropdowntree.htm” and changing the width of the #jqxTree from 200 to 140. As soon as the page loads, you’ll see the scrollbar for the div appear where it would normally appear if the treeview was visible. Before dropping down the treeview, click around the page in the empty space and you’ll see the “phantom” div collapsing as you click.
    I’m using jqWidgets 2.4.2. Is there a fix/workaround — other than making my dropdown tree div large enough to fit the length of any item a user may put in there (i.e. really, really big)?
    Thanks.
    Hi psteele,
    Thank you for the feedback.
    We will test the reported behavior about the jqxTree ScrollBars and if we reproduce it, we will create a work item about it. Usually work items are resolved for an upcoming version which in this case will be jQWidgets ver. 2.6.
    Hi psteele,
    I am writing to confirm the reported issue and to inform you that it will be fixed for the next release scheduled for 21-December-2012.
