jQuery UI Widgets Forums Grid Row filter problem
This topic contains 3 replies, has 3 voices, and was last updated by  Peter Stoev 10 years, 4 months ago.
  • Row filter problem #69331
    msahyilmaz
    Hi, i have a jqx grid and selectionmode is checkbox.
    I am doing the following;
    1- I do before the first election.
    2- I’m filtering.
    3- I select a row in the incoming data
    I chose the value of this data before filtering the results “null” is coming.
    What am I doing wrong?
    Row filter problem #69334
    Nadezhda
    Hello msahyilmaz,
    Please, find a working example below where ‘showfilterrow’ property is set to true and ‘selectionmode’ property is set to checkbox. If this does not help, please provide us with a code sample we can test to determine the source of the issue.
        <title></title>
                var url = "../sampledata/orders.xml";
                    datatype: "xml",
                        { name: 'ShippedDate', map: 'm\\:properties>d\\:ShippedDate', type: 'date' },
                        { name: 'Freight', map: 'm\\:properties>d\\:Freight', type: 'float' },
                        { name: 'ShipName', map: 'm\\:properties>d\\:ShipName', type: 'string' },
                        { name: 'ShipAddress', map: 'm\\:properties>d\\:ShipAddress', type: 'string' },
                        { name: 'ShipCity', map: 'm\\:properties>d\\:ShipCity', type: 'string' },
                        { name: 'ShipCountry', map: 'm\\:properties>d\\:ShipCountry', type: 'string' }
                    root: "entry",
                    record: "content",
                    url: url
                // create jqxgrid.
                $("#jqxgrid").jqxGrid(
                    width: 850,
                    height: 450,
                    showfilterrow: true,
                    selectionmode: 'checkbox',
                    altrows: true,
                      { text: 'Ship Name', datafield: 'ShipName', width: 250 },
                      { text: 'Shipped Date', datafield: 'ShippedDate', width: 100, cellsformat: 'yyyy-MM-dd' },
                      { text: 'Freight', datafield: 'Freight', width: 150, cellsformat: 'F2', cellsalign: 'right' },
                      { text: 'Ship City', datafield: 'ShipCity', width: 150 },
                      { text: 'Ship Country', datafield: 'ShipCountry'}
            <div id="jqxgrid">
    Nadezhda
    Row filter problem #69343
    msahyilmaz
    Hi nadezhda,
    Here is my code:Click Here
    Here is what i am doing:Youtube Video
    Row filter problem #69409
    Hi msahyilmaz,
    We do not find a problem related to jqxGrid’s basic functionality in this code. The problem is in the custom Selection code written in your fiddle. It’s wrong to use “uid” for Row Selection. Row’s Bound Index is expected as Function parameter.
