jQuery UI Widgets › Forums › General Discussions › Layouts › DockPanel › Problems with style="float:right;"
This topic contains 4 replies, has 2 voices, and was last updated by aorlic 13 years, 11 months ago.
Hello!
I just suspect this problem has to do with the DockPanel, maybe it does not.
The above code shows my code that sets up the layout for a wizard-like interface. I would like to place buttons on the extreme right of the bottom dock panel. Therefore, I use float:right style. However this does not work (the button is displayed on the extreme left of his container, instead of the right. BTW, whole DockPanel is inside a Window…
Any ideas?
Here is my code:
// construct the layout
$(‘#npr_dck_main’).jqxDockPanel({ width: ‘100%’, height:560});
$(‘#npr_dck_left’).jqxDockPanel({width: ‘120px’});
$(‘#npr_dck_bottom’).jqxDockPanel({height: ’30px’});
$(‘#npr_dck_main’).jqxDockPanel(‘render’);// buttons
$(‘#mpr_btn_cancel’).jqxButton({ width: ’80px’, height: ’30px’, theme: PMD.theme });
}); // $(document).ready(function () {Hi aorlic,
jqxDockPanel does not support percentage Width and Height in this version. May be this is related to your issue. In addition, it is a layout plug-in so you shouldn’t set ‘floats’ of the HTML elements inside it. The DockPanel will layout its elements depending on their attributes.
http://www.jqwidgets.comThank you Peter.
Do you have any suggestion than, what would be the best way to position my buttons on the extreme right?
Hi aorlic,
You can take a look at the DockPanel’s sample here: dockpanel.htm.
By setting the dock attribute, you specify the element’s position in the layout.
$('#first').attr('dock', 'left'); $('#second').attr('dock', 'left'); $('#third').attr('dock', 'left'); $('#fourth').attr('dock', 'right');
When you set the ‘dock’ attribute of the HTML Element, then call:
$('#jqxDockPanel').jqxDockPanel('render');The above code will arrange the elements.
http://www.jqwidgets.comThank you Peter, I resolved the problem using tables instead of DockPanels… I think it is even better, as I anyway expect to have many widgets on the page.
