jQuery UI Widgets › Forums › Navigation › Menu, Context Menu › Problems with DataAdaptor as Menu Source
Tagged: data adapter, dataadapter, id, jqxDataAdapter, jqxMenu, label, map, Menu, parentId
This topic contains 4 replies, has 2 voices, and was last updated by Gopre400 10 years, 4 months ago.
Hi, I’ve created a SQL table to store Menu Items, the table has three fields (ProjectMenuID, MenuText, and ParentMenuID). I retrieve data from table using a Webservice like this…
var contractorsource = { datatype: "xml", contentType: "application/json; charset=utf-8", datafields: [ { name: 'ProjectMenuID' }, { name: 'MenuText' }, { name: 'ParentMenuID' } ], async: false, record: 'Table', id: 'ProjectMenuID', url: "CNSTWebService.asmx/GetCNSTProjectMenu" };
Then I use a dataAdaptor to bind the data to a Menu
`var dataAdapter = new $.jqx.dataAdapter(contractorsource);
dataAdapter.dataBind();
var records = dataAdapter.getRecordsHierarchy(‘ProjectMenuID’, ‘ParentMenuID’, ‘items’, [{ name: ‘MenuText’, map: ‘label’}]);
$(‘#jqxWidget’).jqxMenu({ source: records, mode: ‘horizontal’, width: ‘300px’ });
$(“#jqxWidget”).on(‘itemclick’, function (event) {
alert(event.args.id);
});’The problem I am having is the dataAdaptor doesn’t appear to be binding the data because the menu doesn’t display. However, I added a combobox using the same dataAdaptor as source then the dataAdaptor binds the data, creates the combo, and creates the menu.
What am I doing wrong?Hello Gopre400,
You also need to map the fields “ProjectMenuID” and “ParentMenuID” to id and parentid respectively as you have already done for “MenuText” and label.
http://www.jqwidgets.com/Thank you Dimitar?
Like this?
var records = dataAdapter.getRecordsHierarchy('id', 'parentid', 'items', [{name: 'ProjectMenuID', map: 'id'},{name: 'ParentMenuID', map: 'parentid'},{ name: 'MenuText', map: 'label'}]);
or this?
var records = dataAdapter.getRecordsHierarchy('ProjectMenuID', 'ParentMenuID', 'items', [{name: 'ProjectMenuID', map: 'id'},{name: 'ParentMenuID', map: 'parentid'},{ name: 'MenuText', map: 'label'}]);
Neither way worked.
It appears to be a problem with the dataAdaptor and/or getting data from Webservice…I took out the Menu to just focus on the dataAdaptor and an error is being thrown…”Internal Server Error.” I’m not sure why…is there a problem with the source (it work as a source of combobox)?
var contractorsource = { datatype: "xml", contentType: "application/json; charset=utf-8", datafields: [ { name: 'ProjectMenuID' }, { name: 'MenuText' }, { name: 'ParentMenuID' } ], async: false, record: 'Table', id: 'ProjectMenuID', url: "CNSTWebService.asmx/GetCNSTProjectMenu" }; var dataAdapter = new $.jqx.dataAdapter(contractorsource, { loadComplete: function () { // get data records. var records = dataAdapter.records; // get the length of the records array. var length = records.length; alert(length); // loop through the records and display them in a table. var html = "<table border='1'><tr><th align='left'>ProjectMenuID</th><th align='left'>MenuText</th>"; for (var i = 0; i < 10; i++) { var record = records[i]; html += "<tr>"; html += "<td>" + record.ParentMenuID + "</td>"; html += "<td>" + record.MenuText + "</td>"; html += "</tr>"; } html += "</table>"; $("#table").html(html); }, loadError: function (jqXHR, status, error) { alert(error); }, beforeLoadComplete: function (records) { } }); dataAdapter.dataBind();
I got it…
var source = { datatype: "xml", datafields: [ { name: 'ProjectMenuID'}, { name: 'MenuText' }, { name: 'ParentMenuID' }, ], async: false, record: 'Table', url: "CNSTWebService.asmx/GetCNSTProjectMenu" }; var dataAdapter = new $.jqx.dataAdapter(source, { contentType: 'application/json; charset=utf-8' } ); dataAdapter.dataBind(); var records = dataAdapter.getRecordsHierarchy('ProjectMenuID', 'ParentMenuID', 'items', [{ name: 'ProjectMenuID', map: 'id'},{ name: 'MenuText', map: 'label'}]); $('#jqxWidget').jqxMenu({ source: records, mode: 'horizontal', width: '300px' }); $("#jqxWidget").on('itemclick', function (event) { alert(event.args.id); }); });
