jQuery UI Widgets Forums Chart Problems when embedding in jqxTabControl
This topic contains 4 replies, has 2 voices, and was last updated by  sdalby 12 years, 7 months ago.
  • Problems when embedding in jqxTabControl #9625
    sdalby
    I have an isse with a chart control showing bars horizontally
    When I insert the div to be displayed in the html to be shown immidiately there are no problems.
    But when I use a jqxTab control that are made visible by clicking a button, and present the bar charts in a tab, all the axis text becomes so small that they are unreadable.
    If I can make this work I also need to turn the rotation of the X axis. I use horizontal bars and I need to write the X axis text horizontally or else it will take up to much space per bar.
    Originally I encapsulated the jqxTabControl in a jqxWindow but I had to give up this approach because it caused problems with a pie chart presented in another tab. It worked with IE but in FF it caused error:
    “Component returned failure code: 0x80004005 (NS_ERROR_FAILURE) [nsIDOMSVGLocatable.getBBox]” nsresult: “0x80004005 (NS_ERROR_FAILURE)”
    The latter is just FYI – I managed to work around it 🙂
    I use followng as bar chart code:
    http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxchart/javascript_chart_bar_series.htm?classic
    Problems when embedding in jqxTabControl #9629
    Hi sdalby,
    jqxChart’s DIV tag should be visible when the widget is initialized. Here’s a sample with jqxTabs and jqxChart: integration.htm.
    Problems when embedding in jqxTabControl #9690
    sdalby
    That worked like a charm, thank you so much.
    Can you tell me how to present the axix text horizontally rather than vertically?
    This is crucial for me.
    Thanks in advance
    /Søren
    Problems when embedding in jqxTabControl #9699
    sdalby
    Also, I have this problem that the value doesnt start with zero. It seem to take offset in the lowest value – this is not desirable for me
    Thanks in advance
    /Søren
    Problems when embedding in jqxTabControl #9701
    sdalby
    Sorry overlooked, the min value, please disregard the question about 0 base on axis
