jQuery UI Widgets Forums General Discussions Navigation Tabs Problem with Tabs and IE
This topic contains 3 replies, has 3 voices, and was last updated by  BenR 10 years, 5 months ago.
  • Problem with Tabs and IE #50663
    Klaus H
    a customer uses IE8 (I know …) and has a problem with a tab I have implemented, it is not displayed as tab at all. You can see the div with the border in the correct size, in the top there is maybe a gray area with 2 or 3 pixel height and on the left there is also a gray area at about 25 pixel. No Javascript error, no indicator something may be wrong with the code. In IE9 it also does not seem to work. In Firefox and Opera it works 100% perfect.
    I have stripped down the code to only the necessary structure to avoid any other sources for the error:
    <DIV ID="jqxtab">
    <UL>
    <LI>Text1</LI>
    <LI>Text2</LI>
    <LI>Text3</LI>
    <LI>Text4</LI>
    <LI>Text5</LI>
    <LI>Text6</LI>
    <LI>Text7</LI>
    <LI>Text8</LI>
    <LI>Text9</LI>
    </UL>
    <DIV>&nbsp;</DIV>
    <DIV>&nbsp;</DIV>
    <DIV>&nbsp;</DIV>
    <DIV>&nbsp;</DIV>
    <DIV>&nbsp;</DIV>
    <DIV>&nbsp;</DIV>
    <DIV>&nbsp;</DIV>
    <DIV>&nbsp;</DIV>
    <DIV>&nbsp;</DIV>
    </DIV>
    The code for creating the grid is very basic:
    $('#jqxtab').jqxTabs({ width: '90%', height: 350, position: 'top'});
    The examples on the jqwidgets page work with the browsers. I use jqwidgets 3.2.1 and jquery 1.9.1
    Only weird thing I find is the difference in the generated source code
    Firefox:
    <div id="jqxtab" aria-disabled="false" class="jqx-tabs jqx-widget jqx-widget-content jqx-rc-all" role="tablist" style="width: 90%; height: 350px;" hidefocus="true" aria-activedescendant="" tabindex="0">
    vs IE:
    <div tabIndex="0" class="jqx-tabs jqx-widget jqx-widget-content jqx-rc-all" id="jqxtab" role="tablist" aria-disabled="false" aria-activedescendant="" style="width: 90%; height: 350px;" hidefocus="true" sizzle-1394187750485="[object Object]" jQuery19107462514088955205="1">
    The sizzle thing seems strange, but I don’t know if that’s a IE or a IE + jqwidgets thing.
    Any idea what might cause a problem like that?
    Problem with Tabs and IE #50669
    Hi Klaus,
    I suggest you to Check your page’s DOCTYPEand look for CSS conflicts.
    Problem with Tabs and IE #50676
    Klaus H
    Hello Peter,
    thank you for the answer, changing the DOCTYPE solved the problem. 🙂
    Best Regards
    Klaus
    Problem with Tabs and IE #67430
    BenR
    Hello all,
    I had a tab close button this thread helped to resolve. I was seeing duplicate close buttons stacked on one another when dynamically adding tabs using both ‘addlast’ and ‘addfirst’ methods. I added the DOCTYPE reference in my page (in this case my ASP.Net MVC view) at the very top before any razor syntax.
    Here is what I added: <!DOCTYPE html>
    I only had the issue in IE9 ( did not test any other versions of IE)
    Tested in Chrome ver 40.0.xxxxx
    FireFox ver:34.0.5
    Testing jQWidgets v3.5.0
    I hope this help someone else.
