jQuery UI Widgets Forums General Discussions Lists ListBox Problem with json & checkboxes
This topic contains 2 replies, has 2 voices, and was last updated by  lior 13 years, 9 months ago.
  • Problem with json & checkboxes #6864
    lior
    Hi.
    I created jqxListBox objet by this code:
    $("#test").jqxListBox({ source: source, checkboxes: true, width: 170, height: 80, theme: theme });
    source look like that:
    var source = [{"label":"a","value":"1"},{"label":"b","value":"2"},{"label":"c","value":"3"},{"label":"d","value":"4"},{"label":"e","value":"5"},{"label":"f","value":"6"}];
    How can i get the selected items?
    The “getSelectedItems” methods always receive me one item.
    var items = $("#test").jqxListBox('getSelectedItems');
    Thanks!
    Problem with json & checkboxes #6878
    Hello lior,
    If you wish to get the checked items, use the method getCheckedItems.
    var items = $("#jqxListBox").jqxListBox('getCheckedItems');
    In your case you have only one selected item and multiple checked ones. If you wish to be able to select multiple items, then you have to set the property multiple to true.
    $("#jqxListBox").jqxListBox({multiple: true});
    Then you may call the getSelectedItems method.
    jqWidgets team
    Problem with json & checkboxes #6901
    lior
    Thanks! 🙂
