jQuery UI Widgets Forums General Discussions Navigation Tree Problem with checkboxes overrunning bottom of tree
This topic contains 3 replies, has 3 voices, and was last updated by  Hristo 7 years, 5 months ago.
  • tomintex
    I have a jqxTree control which I populate using a source object. It displays correctly initially – see below:
    [IMG]http://i65.tinypic.com/2cmqfci.png[/IMG]
    However, when I expand it, the checkboxes run over the bottom of the control. See below:
    [IMG]http://i64.tinypic.com/2wpkp69.png[/IMG]
    The control resides in a div structure:
    <div class=”row”>
    <div class=”col-lg-2″></div>
    <div class=”col-lg-3″ style=”height: 500px; border-width: 2px; border-style: solid; border-color: #8eb7f9; margin-right: 10px;
    border-radius: 2px; padding-top: 10px;”>
    <div id=’jqxrightTree’ style=”overflow: auto”></div></div>
    and is created as follows:
    $(‘#jqxrightTree’).jqxTree({ source: rightsource, height: ‘470px’, width: ‘450px’, checkboxes: true, hasThreeStates: true });
    $(‘#jqxrightTree’).css(‘visibility’, ‘visible’);
    Any ideas as to what I am doing wrong?
    TomA
    Hello TomA,
    I tested this example and it seems to work fine.
    Please, try to check if you set some additional style settings.
    Also, if you have any error messages in the console, please, tell me.
    JenkeNg
    hello,I’ve had this problem, too.How did you solve it?
    Hello JenkeNg,
    I would like to ask you did you look the example that I suggest above.
    Also, could you provide us an example that demonstrates your issue?
