jQuery UI Widgets Forums Navigation Tree Problem with Ajax Tree Demo
This topic contains 4 replies, has 3 voices, and was last updated by  lee-da 12 years, 4 months ago.
  • Problem with Ajax Tree Demo #15425
    lee-da
    I’m using your “Load on Demand with Ajax” Demo for creating a dynamic Tree with PHP. My problem now is that your method only works for the first level. As soon as the second level is loaded (with new “Loading…” subitems) another expand click on the parent element now loads the subitems of the first item in level 2. This is due to .find(“li”). And now these subitems are appended to the parent element.
    Wrong:
    Level1-1
    Level1-2
          Level2-1
        – Level2-2
        – Level3-1 (loaded after expanding Level1-2 twice)
    Right:
    Level1-1
    Level1-2
        – Level2-1
            – Level3-1 (loaded after expanding Level2-1)
        – Level2-2
    So, I modified your script to stop loading subitems if the element’s parent is not equal to the expanded item (excludes levels >1):
    tree.on('expand', function(event) {
    var $element = $(event.args.element);
    var children = $element.find('li');
    $.each(children, function() {
    var item = tree.jqxTree('getItem', this);
    if (item.label == 'Loading...'&&item.parentElement==$element[0]) {
    $.getJSON('data.php',{
    load: 'leaf',
    function(data){
    tree.jqxTree('addTo', data, $element[0]);
    tree.jqxTree('removeItem', item.element);
    return;
    Now my question:
    Is there a way to simplify this a bit? Is there maybe a jqxTree method to access only first level items?
    Or could removing the “expand” binding for already-loaded items be a good approach?
    Thanks.
    Problem with Ajax Tree Demo #15444
    admin
    Hi lee-da,
    There is already a post about that: http://www.jqwidgets.com/community/topic/jqxtree-load-on-demand-with-ajax-re-open-issue/
    Problem with Ajax Tree Demo #15448
    lee-da
    Thanks. I’ll give that “ul:first” thing a try.
    Btw, do you plan to implement a forum search? This could be more precise than Google – or maybe a Google plugin, for instance?
    @Community:
    For the time being, googling “site:jqwidgets.com/community <your keywords>” gives quite good results.
    Problem with Ajax Tree Demo #15455
    Hi lee-da,
    There is already Forum Search. When you login into your account, there is a search icon at the top-right corner of your screen. When you click it, a search field will be displayed.
    Problem with Ajax Tree Demo #15458
    lee-da
    Ok, a little unobtrusive – but it works. 🙂
    Thanks.
