jQuery UI Widgets Forums Navigation Tree problem with 'addTo' function
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 3 months ago.
  • problem with 'addTo' function #15165
    bartsimp
    hi,
    I’ve two tree:
    <div id='jqxTreeSrc' style="float:left;">
    <ul>
    <li id="1" parentId="-1">Sport
    <ul>
    <li id="2" parentId="1">Tennis</li>
    <li id="3" parentId="1">Basket</li>
    </ul>
    </li>
    <div id='jqxTreeDst' style="float:left;">
    If I use
    $(“#jqxTreeDst”).jqxTree(‘addTo’, item);
    to add an item from jqxTreeSrc to jqxTreeDst, the destination tree don’t preserve the attribute parentId.
    I think that the problem is in _parseItem function called by addTo which does not take account of that attribute.
    Do you plan to fix it?
    problem with 'addTo' function #15167
    Hi bartsimp,
    The ‘addTo’ method is supposed to be used in the way demonstrated in this sample: settings.htm. To add an item as a sub item, you need to pass the sub item’s element as parameter to the “addTo” method, too.
    problem with 'addTo' function #15213
    bartsimp
    I’ve some problem with the “settings.htm” sample:
    after to remove all the nodes with the “remove” button, if you click “add” button nothing happen
    Maybe a bug?
    problem with 'addTo' function #15216
    Hi bartsimp,
    You can see in the sample that when the “Add” button is clicked, a tree item is added as a sub item of the selected tree item. When you remove all items, there is no longer a selected item so clicking the button will not add items.
