jQuery UI Widgets Forums Chart Performance Problem When Trying to Upgrade to 3.4
This topic contains 2 replies, has 2 voices, and was last updated by  swarren 11 years ago.
  • swarren
    I’m trying to upgrade my site to 3.4 from 3.1 and I have a page that displays several jqxCharts (4 of them) and the page takes forever to load after switching to 3.4. The code below takes upwards of 15 seconds per graph when run with 3.4 but usually less than a second per graph when run with 3.1. I’ve tried reducing the code further but this seems like the smallest I can make it and have it still run. Any suggestions on how to improve this?
    <html>
    <body>
    <div class=”test”>
    [{“No”:0,”No Answer”:0,”Yes”:100,”data”:”2013-03″},{“No”:0,”No Answer”:0,”Yes”:100,”data”:”2013-04″},{“No”:14.285714285714,”No Answer”:14.285714285714,”Yes”:71.428571428571,”data”:”2013-05″},{“No”:0,”No Answer”:8.3333333333333,”Yes”:91.666666666667,”data”:”2013-06″},{“No”:0,”No Answer”:0,”Yes”:100,”data”:”2013-07″},{“No”:0,”No Answer”:20,”Yes”:80,”data”:”2013-08″},{“No”:0,”No Answer”:14.285714285714,”Yes”:85.714285714286,”data”:”2013-09″},{“No”:0,”No Answer”:0,”Yes”:100,”data”:”2013-10″},{“No”:20,”No Answer”:0,”Yes”:80,”data”:”2013-11″},{“No”:0,”No Answer”:20,”Yes”:80,”data”:”2013-12″},{“No”:0,”No Answer”:20,”Yes”:80,”data”:”2014-01″},{“No”:0,”No Answer”:0,”Yes”:100,”data”:”2014-02″},{“No”:0,”No Answer”:0,”Yes”:100,”data”:”2014-03″},{“No”:12.5,”No Answer”:0,”Yes”:87.5,”data”:”2014-04″},{“No”:0,”No Answer”:0,”Yes”:100,”data”:”2014-05″},{“No”:0,”No Answer”:33.333333333333,”Yes”:66.666666666667,”data”:”2014-06″}]
    <link rel=”stylesheet” href=”/jqwidgets-ver3.4.0/jqwidgets/styles/jqx.base.css” type=”text/css” />
    <script type=”text/javascript” src=”/jqwidgets-ver3.4.0/scripts/jquery-1.10.2.min.js”></script>
    <script type=”text/javascript” src=”/jqwidgets-ver3.4.0/jqwidgets/jqx-all.js”></script>
    <script>
    $(function(){
    console.time(‘startup’);
    var element = $(‘.test’);
    var data = $.parseJSON(element.text());
    var source = {
    datatype:’array’,
    localdata:data,
    datafields:[
    {name: ‘No’},
    {name: ‘No Answer’},
    {name: ‘Yes’},
    {name: ‘data’},
    settings = {
    source:dataAdapter,
    categoryAxis:{
    dataField: ‘data’,
    seriesGroups:[
    type: ‘line’,
    valueAxis:
    unitInterval: 5,
    displayValueAxis: true,
    tickMarksColor: ‘#888888’
    series:[
    {dataField: ‘No’},
    {dataField: ‘No Answer’},
    {dataField: ‘Yes’},
    console.timeEnd(‘startup’);
    console.time(‘jqxChart’);
    element.jqxChart(settings);
    console.timeEnd(‘jqxChart’);
    Hello swarren,
    Please try the following, updated, version of your code:
    <html>
        <script type="text/javascript" src="../../jqwidgets/jqx-all.js"></script>
            $(function () {
                console.time('startup');
                var element = $('.test');
                var source = {
                    datatype: 'array',
                    localdata: data,
                    datafields: [{
                        name: 'data', type: 'date'
                settings = {
                    categoryAxis: {
                        dataField: 'data',
                        type: 'date',
                        baseUnit: 'month'
                    seriesGroups: [{
                        type: 'line',
                        valueAxis: {
                            unitInterval: 5,
                            tickMarksColor: '#888888'
                        series: [{
                            dataField: 'No'
                            dataField: 'No Answer'
                            dataField: 'Yes'
                console.timeEnd('startup');
                console.time('jqxChart');
                element.html("");
                console.timeEnd('jqxChart');
    <body>
        <div class="test" style="width: 500px; height: 300px;">
            [{"No":0,"No Answer":0,"Yes":100,"data":"2013-03"},{"No":0,"No Answer":0,"Yes":100,"data":"2013-04"},{"No":14.285714285714,"No Answer":14.285714285714,"Yes":71.428571428571,"data":"2013-05"},{"No":0,"No Answer":8.3333333333333,"Yes":91.666666666667,"data":"2013-06"},{"No":0,"No Answer":0,"Yes":100,"data":"2013-07"},{"No":0,"No Answer":20,"Yes":80,"data":"2013-08"},{"No":0,"No Answer":14.285714285714,"Yes":85.714285714286,"data":"2013-09"},{"No":0,"No Answer":0,"Yes":100,"data":"2013-10"},{"No":20,"No Answer":0,"Yes":80,"data":"2013-11"},{"No":0,"No Answer":20,"Yes":80,"data":"2013-12"},{"No":0,"No Answer":20,"Yes":80,"data":"2014-01"},{"No":0,"No Answer":0,"Yes":100,"data":"2014-02"},{"No":0,"No Answer":0,"Yes":100,"data":"2014-03"},{"No":12.5,"No Answer":0,"Yes":87.5,"data":"2014-04"},{"No":0,"No Answer":0,"Yes":100,"data":"2014-05"},{"No":0,"No Answer":33.333333333333,"Yes":66.666666666667,"data":"2014-06"}]
    swarren
    Adding the baseUnit property fixed the problem. Thanks!
