jQuery UI Widgets › Forums › General Discussions › Editors › CheckBox, RadioButton › Not working demos for knockout.js integration
This topic contains 5 replies, has 2 voices, and was last updated by cziz 12 years, 4 months ago.
Hi guys,
I just tried to check and play with your widgets and knockout.js.
my source code:
jqxCheckBox$(document).ready(function () {
var viewModel = function (value) {
this.count = 0;
this.checked = ko.observable(value);
this.disabled = ko.observable(false);
// display checked state.
this.getState = function () {
alert(“Checked: ” + this.checked());
// check checkbox.
this.check = function () {
this.checked(true);
// toggle disabled state.
this.toggle = function () {
this.count++;
this.disabled(this.count % 2);
ko.applyBindings(new viewModel(true));
});It is coppied directly from your site. Buttons works fine but checkbox is not rendering at all. I can see only jqxCheckBox text.
I’m guessing that it might be related to newer jquery and knockout than you used in examples. I have the newest version of jqwidgets.
There is no error in js. Any ideas?
Hi cziz,
Please, check whether you have included jqxcheckbox.js in your project. The jQuery version required for jQWidgets is jQuery 1.7+.
Here is the working CheckBox with Knockout integration demo: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxknockout/checkbox.htm?classic
Peter SToevjQWidgets Team
Yup, i included all needed stuff. I checked even if paths are ok, and they are.
<link href="/Content/site.css" rel="stylesheet"/> <link href="/Scripts/jqwidgets/styles/jqx.base.css" rel="stylesheet"/><link href="/Scripts/jqwidgets/styles/jqx.classic.css" rel="stylesheet"/> <script src="/Scripts/modernizr-2.5.3.js"></script> <script src="/Scripts/jquery-1.9.1.js"></script> <script src="/Scripts/jqwidgets/jqxcore.js"></script><script src="/Scripts/jqwidgets/jqxdata.js"></script><script src="/Scripts/jqwidgets/jqxbuttons.js"></script><script src="/Scripts/jqwidgets/jqxscrollbar.js"></script><script src="/Scripts/jqwidgets/jqxmenu.js"></script><script src="/Scripts/jqwidgets/jqxlistbox.js"></script><script src="/Scripts/jqwidgets/jqxgrid.js"></script><script src="/Scripts/jqwidgets/jqxgrid.selection.js"></script><script src="/Scripts/jqwidgets/jqxgrid.columnsresize.js"></script><script src="/Scripts/jqwidgets/jqxgrid.edit.js"></script><script src="/Scripts/jqwidgets/jqxknockout.js"></script><script src="/Scripts/jqwidgets/jqxcheckbox.js"></script><script src="/Scripts/json2.js"></script><script src="/Scripts/knockout-2.2.1.debug.js"></script>
Hi cziz,
The Knockout plug-in should be included before jqxknockout.js, because jqxknockout.js uses that plugin. In addition, make sure that all paths are correct and you run the code in the jQuery’s document.ready function.
Here’s a working code:
<!DOCTYPE html><html lang="en"><head> <title id="Description">Integration of jqxCheckBox with Knockout</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.8.2.min.js"></script> <script type="text/javascript" src="../../scripts/json2.js"></script> <script type="text/javascript" src="../../scripts/knockout-2.1.0.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxknockout.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript"> $(document).ready(function () { var viewModel = function (value) { this.count = 0; this.checked = ko.observable(value); this.disabled = ko.observable(false); // display checked state. this.getState = function () { alert("Checked: " + this.checked()); } // check checkbox. this.check = function () { this.checked(true); } // toggle disabled state. this.toggle = function () { this.count++; this.disabled(this.count % 2); } }; ko.applyBindings(new viewModel(true)); }); </script></head><body class='default'> <div data-bind="jqxCheckBox: {checked: checked, disabled: disabled, width: '120px', theme: getDemoTheme()}" style='margin-bottom: 10px;'>jqxCheckBox</div> <input data-bind="click: getState, jqxButton: {theme: getDemoTheme()}" type="button" value="Get Value" /> <input data-bind="click: check, jqxButton: {theme: getDemoTheme()}" type="button" value="Set Value" /> <input data-bind="click: toggle, jqxButton: {theme: getDemoTheme()}" type="button" value="Toggle Disabled" /></body></html>
http://www.jqwidgets.comashamed…
thanks for help -
