jQuery UI Widgets Forums Grid Labeling filter values in grid
This topic contains 3 replies, has 3 voices, and was last updated by  fdski 10 years, 5 months ago.
  • Labeling filter values in grid #24976
    timtate
    I’m trying to filter a grid by certain values, but don’t want the user to see those values in the checkedlist. I want those values to have a label instead, but filtering based on the selected values.
    I tried setting up the column like this:
    text: 'Priority',
    datafield: 'priCode',
    filtertype: 'checkedlist',
    filteritems: [
    { value: 1, label: "Critical" },
    { value: 10, label: "High" },
    { value: 20, label: "Medium" },
    { value: 30, label: "Low" },
    { value: 99, label: "OToG" },
    editable: false,
    pinned: true
    But this results in a dropdown that has checkboxes with blank labels, and selecting one of the options does not filter based on the hidden value.
    If I use a simple array, like this:
    filteritems: ['1', '10', '20', '30', '99']
    I at least get correct filtering, but like I said I want to label them.
    Labeling filter values in grid #24989
    Hello timtate,
    Unfortunately, this functionality is not supported by jqxGrid.
    Labeling filter values in grid #25034
    timtate
    Ah, well consider it a feature request then 😛
    Labeling filter values in grid #63968
    fdski
    +1
