jQuery UI Widgets Forums Layouts Kanban Kanban-Card-Drag-Issue
This topic contains 7 replies, has 5 voices, and was last updated by  Hristo 5 years, 5 months ago.
  • Kanban-Card-Drag-Issue #89322
    CRaSH
    Situation:
    I have a number of Kanban Boards being fed via the dataAdapter and a dropdown selector.
    One of these boards needs to have 10 Columns (swimlanes).
    All Items (cards) need to have fixed-widths of 400px.
    All boards must overflow-x:scroll instead of wrap.
    The Kanban needs to be set width:auto in order to cater for the variation in number of columns.
    This all works/renders perfectly.
    Problem:
    It’s impossible to reliably move a card that was rendered in a column where that column was rendered beyond the pixel width of the browser window.
    That is to say, any card that was rendered in a column that you need to scroll to – in order to view – can’t be moved properly.
    It’s as if the the script loses all understanding of where the card came from or where it could be moved to.
    I spent some time creating a JS Editor Example to demonstrate the behavior, saved it as ‘Kanban-Card-Drag-Issue’…but can’t seem to locate it now to provide a link (grrr).
    Here is a much simpler example version:
    Any thoughts/ideas on how to fix this would be greatly appreciated.
    Kanban-Card-Drag-Issue #89349
    Hello CRaSH,
    Thank you for this feedback.
    Kanban-Card-Drag-Issue #92337
    roblajolla
    Has there been a resolution to this? It seems that when part of the kanban is not displayed the drag and drop coordinates are not calculated properly. I am experiencing a problem where the kanban item I’m dragging appears 8 inches outside of the kanban.
    Rob
    Kanban-Card-Drag-Issue #92349
    Hello Rob,
    Unfortunately, no for now.
    You could find new things (and fixes) in the Release History.
    Thank you for your understanding.
    Kanban-Card-Drag-Issue #105365
    pabjiiz
    I’m having the same issue yet …
    When will it be fixed ?
    pabjiiz.
    Kanban-Card-Drag-Issue #105388
    Hello pabjiiz,
    Thank you for the interest.
    This is still valid issue.
    We cannot engage with deadlines.
    We work on different tasks with a different priority.
    Please let me know if you have any other questions.
    https://www.jqwidgets.com
    Kanban-Card-Drag-Issue #107967
    alnebras
    How to add dropdown to cards in kanban
    Kanban-Card-Drag-Issue #107972
    Hello alnebras,
    There is no such built-in feature for this, unfortunately.
    If you want you could bind to itemAttrClicked event and when the user clicking on it then show a window with such dropdown.
    Also, you could contact the the Sales Department (sales@jqwidgets.com) with request for custom development.
    Let me know if you need anything else.
