jQuery UI Widgets Forums Navigation Tree jqxTree collapseItem Problem
This topic contains 2 replies, has 2 voices, and was last updated by  gibafsar 11 years, 10 months ago.
  • jqxTree collapseItem Problem #26192
    gibafsar
    I use jqxTree and I defined this function for select item by value:
        function GetjqxTreeItemByValue(jqxTreeObject, value) {
            var rItem = null;
            var TreeItems = jqxTreeObject.jqxTree(‘getItems’);
            for (var i in TreeItems) {
                jqxTreeObject.jqxTree(‘expandItem’, TreeItems[i]);
                if (TreeItems[i][‘value’] == value) {
                    rItem = TreeItems[i];
                    break;
                jqxTreeObject.jqxTree(‘collapseItem’, TreeItems[i]);
            return rItem;
    Everything is good working but collapseItem row. I tried this row stand alone and it’s worked but in this case it’s not working.
    I’m waiting for help.
    Thanks;
    Note: I’m using jqx-all.js and v2.9.3
    jqxTree collapseItem Problem #26303
    Hi gibafsar,
    The code will not work because it is not possible to expand and collapse a Tree item at the same time. You can collapse an item after it is expanded i.e after the expand animation has completed.
    jqxTree collapseItem Problem #26320
    gibafsar
    Thank you very much for your answer Peter.
    I’ll try another way to solve this problem perforce or I may leave it in this case. It won’t be big problem.
