jQuery UI Widgets › Forums › Angular › JQXLite is not defined
This topic contains 3 replies, has 3 voices, and was last updated by Ivo Zhulev 6 years, 3 months ago.
AuthorJQXLite is not defined Posts
So I’m using jqxChartComponents, using the jqwidgets-ng package and exerything works fine while im testing and even building for development. However when I build my application for production with
ng build –prod –base-href .
and I deploy it to a tomcat server, the charts stop working and I get the following error on the consolemain.d414d12cf6aaddaf809d.js:1 ERROR Error: Uncaught (in promise): ReferenceError: JQXLite is not defined
at new t (main.d414d12cf6aaddaf809d.js:1)
at Mi (main.d414d12cf6aaddaf809d.js:1)
at ji (main.d414d12cf6aaddaf809d.js:1)
at la (main.d414d12cf6aaddaf809d.js:1)
at _a (main.d414d12cf6aaddaf809d.js:1)
at ma (main.d414d12cf6aaddaf809d.js:1)
at ia (main.d414d12cf6aaddaf809d.js:1)
at Object.xa [as createRootView] (main.d414d12cf6aaddaf809d.js:1)
at e.create (main.d414d12cf6aaddaf809d.js:1)
at P (polyfills.8bbb231b43165d65d357.js:1)
at polyfills.8bbb231b43165d65d357.js:1
at e.invokeTask (polyfills.8bbb231b43165d65d357.js:1)
at Object.onInvokeTask (main.d414d12cf6aaddaf809d.js:1)
at t.runTask (polyfills.8bbb231b43165d65d357.js:1)
at g (polyfills.8bbb231b43165d65d357.js:1)
at t.invokeTask [as invoke] (polyfills.8bbb231b43165d65d357.js:1)
at m (polyfills.8bbb231b43165d65d357.js:1)this only happens when I build for production, and this error only happens when I try to load any page with a chart on it. How could I fix it?
Hello abilbaolavieja,
Could you, please, try to reinstall the latest version of jqwidgets-ng (delete node_modules and the dependency in package.json before that) and check of you still encounter this issue.
If this doesn’t help, please, send us an example of how you are using the chart.
Thank you!Best Regards,
MartinjQWidgets Team
http://www.jqwidgets.com/Hi Martin
I reinstalled jqwidgets-ng 2 or 3 times before posting this questions, and the issue remained. However I decided to build my project with this command
ng build –prod –base-href=. –aot=false –buildOptimizer=false
and it is working now. If you still need to check how I’m using the chart here is the code
TS fileselectedServerSessionSpaceObjectsLoadTime: SpaceObjectLoadTime[]; xAxis: any = { dataField: 'date', rangeSelector: { size: 100, dataField: 'loadTime', showGridLines: false } }; padding: any = { left: 50, top: 5, right: 50, bottom: 5 }; colorScheme = 'scheme01'; seriesGroups: any[] = [{ type: 'line', series: [{ dataField: 'loadTime', displayText: 'Loading Time (ms)' }] }]; getWidth() { return '1200'; } getHeight() { return '800'; }
HTML file:
<jqxChart #sessionChart id="space-objects-chart" [width]="getWidth()" [height]="getHeight()" [colorScheme]="colorScheme" [source]="selectedServerSessionSpaceObjectsLoadTime" [xAxis]="xAxis" [seriesGroups]="seriesGroups" [padding]="padding" [title]="'Title'" [description]="''"> </jqxChart>
Hi abilbaolavieja,
Can you please confirm you are using
jqwidgets-ng
version7.2.1
?Best Regards,
IvojQWidgets Team
