jQuery UI Widgets Forums Navigation Tree Jqx Tree Right Click Issue with source property
This topic contains 1 reply, has 2 voices, and was last updated by  Nadezhda 10 years, 2 months ago.
  • abrahamdivyatej
    I just want to know how can i attach context menu to a particular element in jqxTree given that list elements are not given.
    Data is given through source property.
    Nadezhda
    Hello abrahamdivyatej,
    Here is an example which shows how to use ‘source’ property and Context Menu on jqxTree. jqxTree always contains li elements.
        <title></title>
        <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script>
                var source = [
                     label: "Item 1", expanded: true, items: [
                       { label: "Item 1.1" },
                       { label: "Item 1.2", selected: true }
                 { label: "Item 2" },
                 { label: "Item 3" },
                     label: "Item 4", expanded: true, items: [
                       { label: "Item 4.1" },
                       { label: "Item 4.2" }
                 { label: "Item 5" },
                 { label: "Item 6" },
                 { label: "Item 7" }
                // Create jqxTree
                $('#jqxTree').jqxTree({ source: source, height: '350px', width: '300px' });
                $('#jqxTree').css('visibility', 'visible');
                var contextMenu = $("#jqxMenu").jqxMenu({ width: '120px', height: '56px', autoOpenPopup: false, mode: 'popup' });
                var clickedItem = null;
                var attachContextMenu = function () {
                    // open the context menu when the user presses the mouse right button.
                    $("#jqxTree li").on('mousedown', function (event) {
                        var target = $(event.target).parents('li:first')[0];
                        var rightClick = isRightClick(event);
                        if (rightClick && target != null) {
                            $("#jqxTree").jqxTree('selectItem', target);
                            contextMenu.jqxMenu('open', parseInt(event.clientX) + 5 + scrollLeft, parseInt(event.clientY) + 5 + scrollTop);
                            return false;
                attachContextMenu();
                $("#jqxMenu").on('itemclick', function (event) {
                    var item = $.trim($(event.args).text());
                    switch (item) {
                        case "Add Item":
                            var selectedItem = $('#jqxTree').jqxTree('selectedItem');
                            if (selectedItem != null) {
                                $('#jqxTree').jqxTree('addTo', { label: 'Item' }, selectedItem.element);
                            break;
                        case "Remove Item":
                                $('#jqxTree').jqxTree('removeItem', selectedItem.element);
                            break;
                // disable the default browser's context menu.
                $(document).on('contextmenu', function (e) {
                    if ($(e.target).parents('.jqx-tree').length > 0) {
                        return false;
                    return true;
                function isRightClick(event) {
                    var rightclick;
                    if (!event) var event = window.event;
                    if (event.which) rightclick = (event.which == 3);
                    else if (event.button) rightclick = (event.button == 2);
                    return rightclick;
        <div id='jqxTree' style='visibility: hidden; float: left; margin-left: 20px;'>
        <div id='jqxMenu'>
            <ul>
                <li>Add Item</li>
                <li>Remove Item</li>
            </ul>
    Nadezhda
