jQuery UI Widgets Forums Grid Issues when using initEditor and validation together
This topic contains 5 replies, has 2 voices, and was last updated by  Dimitar 11 years, 2 months ago.
  • deepak_chaurasia
    Hi Team,
    I am calling endcelledit from initeditor of a cell and i have applied validation rule on the same. Issue that i’m facing is that when control is going inside initeditor it is working fine for the first time , But if some validation failure has happened and if i’m invoking 2nd time initeditor , at that moment i’m getting editor as undefined,
    Please clarify why this is happening?
    Hello deepak_chaurasia,
    Please post an example demonstrating the issue (preferably at JSFiddle), which we may test to determine why it occurs.
    deepak_chaurasia
    Hi ,
    Please find the sample code for the same:
    <html lang=”en”>
    <title id=’Description’>In order to enter in edit mode, select a grid cell and start typing, “Click” or press the “F2” key. You
    can also navigate through the cells using the keyboard arrows or with the “Tab” and “Shift + Tab” key combinations. To cancel the cell editing, press the “Esc” key. To save
    the changes press the “Enter” key or select another Grid cell. Pressing the ‘Space’ key when a checkbox cell is selected will toggle the check state.</title>
    <link rel=”stylesheet” href=”js/externallibs/jqxwidgets_upgrade/styles/jqx.base.css” type=”text/css” />
    <script type=”text/javascript” src=”js/externallibs/jquery-1.11.2.min.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxcore.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxdata.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxmenu.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxgrid.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxgrid.edit.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxgrid.selection.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxlistbox.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxdropdownlist.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxcheckbox.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxcalendar.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxnumberinput.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/jqxdatetimeinput.js”></script>
    <script type=”text/javascript” src=”js/externallibs/jqxwidgets_upgrade/globalization/globalize.js”></script>
    <script type=”text/javascript” src=”js/externallibs/generatedata.js”></script>
    var data = generatedata(200);
    localdata: data,
    datatype: “array”,
    // and with parameter false if the synchronization failder.
    commit(true);
    datafields:
    { name: ‘available’, type: ‘bool’ },
    { name: ‘price’, type: ‘number’ },
    { name: ‘date’, type: ‘date’ }
    // initialize jqxGrid
    $(“#jqxgrid”).jqxGrid(
    width: 850,
    enabletooltips: true,
    text: ‘Ship Date’, datafield: ‘date’, columntype: ‘datetimeinput’, width: 110, align: ‘right’, cellsalign: ‘right’, cellsformat: ‘d’,
    validation: function (cell, value) {
    if (value == “”)
    return true;
    var year = value.getFullYear();
    if (year >= 2015) {
    return { result: false, message: “Ship Date should be before 1/1/2015” };
    return true;
    initeditor : function (row, cellvalue, editor, celltext, cellwidth, cellheight) {
    editor.jqxDateTimeInput({showFooter:true});
    editor.unbind(‘change’).bind(‘change’,function(){
    $(“#jqxgrid”).jqxGrid(‘endcelledit’, row, this.datafield, false, true ,false);
    { text: ‘Price’, datafield: ‘price’, align: ‘right’, cellsalign: ‘right’, cellsformat: ‘c2’, columntype: ‘numberinput’,
    if (value < 0 || value > 15) {
    return { result: false, message: “Price should be in the 0-15 interval” };
    return true;
    editor.jqxNumberInput({ digits: 3 });
    <body class=’default’>
    <div id=’jqxWidget’>
    <div id=”jqxgrid”></div>
    <div style=”font-size: 12px; font-family: Verdana, Geneva, ‘DejaVu Sans’, sans-serif; margin-top: 30px;”>
    <div id=”cellbegineditevent”></div>
    <div style=”margin-top: 10px;” id=”cellendeditevent”></div>
    In htis example if i change Ship Date. it is binded dynamically to grid , but if i change date to some value which is invalid (in this case date more than 1/1/2015). error message is getting displayed but when i again click on that same cell , i get “This.editcell is undefined” error in console.
    Please see into this issue
    Hi deepak_chaurasia,
    This issue occurs because of the call to endcelledit in initeditor. You should avoid this and implement a different solution.
    deepak_chaurasia
    Currently I am doing this , but as you said i should avoid it , is there any work around for this , my requirement is that without clicking anywhere else on grid i should be able to bind data to grid cell. Please provide any solution to it.
    I am not sure I understand – do you wish to refresh only a particular cell? If you wish to do it for the whole grid, it can be achieved with methods such as refresh and updatebounddata.
    For a single cell you may try calling begincelledit and endcelledit consecutively but I am not sure if this will suit your purposes.
