jQuery UI Widgets Forums Grid issue with refresh
This topic contains 2 replies, has 2 voices, and was last updated by  jperera 10 years, 2 months ago.
  • issue with refresh #68374
    jperera
    Hello Peter,
    Look I did the set of the datasource of a grid and it works fine when I’m calling from a function, but I need calling it in the event addrow, updaterow and deleterow. The problem is when I put the change of the datasource in any one of the event addrow or updaterow or deleterow I get the following exception:
    Unhandled exception at line 7, column 151838 in http://localhost:59655/Scripts/JQWidgets/jqxgrid.js
    0x800a139e – JavaScript runtime error: jqxGrid: The data is still loading. When the data binding is completed, the Grid raises the ‘bindingcomplete’ event. Call this function in the ‘bindingcomplete’ event handler.
    My goal is that when you update, delete or add to the grid call the function to update it…
    Any help please??
    Jose
    issue with refresh #68403
    Hello Jose,
    Please make sure you have implemented these functionalities as shown in the help topics Build CRUD Web App with jqxGrid using PHP and MySQL and CRUD with jqxGrid, ASP.NET MVC3 and SQL (check out the one relevant to your server environment).
    issue with refresh #68413
    jperera
    Thank you very much Dimitar for your advice, I think the problem is the ajax cache.
    I Appreciate a lot your help
