jQuery UI Widgets › Forums › General Discussions › Navigation › Tree › How to setting checked state between perentElement and element and childElement?
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 12 years, 2 months ago.
May 9, 2013 at 9:09 am How to setting checked state between perentElement and element and childElement? #20820
the ‘checkAll’ and ‘uncheckAll’ methods can’t meet the actual demand,because my tree has many level.
Here is an example:
<!DOCTYPE html><html lang="en"><head> <meta name="keywords" content="jQuery Tree, Tree Widget, Tree" /> <meta name="description" content="The jqxTree can display a checkboxes next to its items. You can also enable three-state checkboxes. In this mode, when the user checks an item, its sub items also become checked. When there is an unchecked item, the parent item is in indeterminate state." /> <title id='Description'>The jqxTree can display a checkboxes next to its items. You can also enable three-state checkboxes. In this mode, when the user checks an item, its sub items also become checked. When there is an unchecked item, the parent item is in indeterminate state.</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript"> $(document).ready(function () { // Create jqxTree var theme = getDemoTheme(); // create jqxTree $('#jqxTree').jqxTree({ height: '400px', checkboxes: true,hasThreeStates: true, width: '330px', theme: theme }); var items = $('#jqxTree').jqxTree('getItems'); var firstLevelItems = new Array(); for (var i = 0; i < items.length; i++) { if (items[i].level == 1) { firstLevelItems.push(items[i]); }; }; $('#jqxTree').on('checkChange',function(event){ var args = event.args; var element = args.element; var checked = args.checked; // if(checked) // $('#jqxTree').jqxTree('checkAll'); // else // $('#jqxTree').jqxTree('uncheckAll'); if(checked){ var checkedLevel = $('#jqxTree').jqxTree('getItem', element).level; var nextItem = $('#jqxTree').jqxTree('getNextItem',element); while(nextItem.level > checkedLevel){ $('#jqxTree').jqxTree('expandItem', nextItem); $('#jqxTree').jqxTree('checkItem', nextItem, true); $('#jqxTree').jqxTree('collapseItem', nextItem); nextItem = $('#jqxTree').jqxTree('getNextItem',nextItem); } } }); }); </script></head><body class='default'> <div id='jqxTree' style='float: left; margin-left: 20px;'> <ul> <li id='home'>Home</li> <li item-expanded='true'>Solutions <ul> <li>Education</li> <li>Financial services</li> <li>Government</li> <li>Manufacturing</li> <li>Solutions <ul> <li>Consumer photo and video</li> <li>Mobile</li> <li>Rich Internet applications</li> <li>Technical communication</li> <li>Training and eLearning</li> <li>Web conferencing</li> </ul> </li> <li>All industries and solutions</li> </ul> </li> <li>Products <ul> <li>PC products</li> <li>Mobile products</li> <li>All products</li> </ul> </li> <li>Support <ul> <li>Support home</li> <li>Customer Service</li> <li>Knowledge base</li> <li>Books</li> <li>Training and certification</li> <li>Support programs</li> <li>Forums</li> <li>Documentation</li> <li>Updates</li> </ul> </li> <li>Communities <ul> <li>Designers</li> <li>Developers</li> <li>Educators and students</li> <li>Partners</li> <li>By resource <ul> <li>Labs</li> <li>TV</li> <li>Forums</li> <li>Exchange</li> <li>Blogs</li> <li>Experience Design</li> </ul> </li> </ul> </li> <li>Company <ul> <li>About Us</li> <li>Press</li> <li>Investor Relations</li> <li>Corporate Affairs</li> <li>Careers</li> <li>Showcase</li> <li>Events</li> <li>Contact Us</li> <li>Become an affiliate</li> </ul> </li> </ul> </div></body></html>
I want make the checkbox has three states,
and hen I click one checkbox ,it’s child checkbox could be checked or unchecked automatic.
When I using the “checkAll” and the “uncheckAll” methods,the FireFox report “too much recursion” error and the IE browser report stack overflow.
May 9, 2013 at 9:23 am How to setting checked state between perentElement and element and childElement? #20821Hi,
Well, the problem in that code is that you call “checkAll” in checkChange method which is raised when the Check State is changed. However, by calling a method which checks checkboxes it will also raise checkChange event and you will call again checkAll method and so on.
