jQuery UI Widgets Forums Grid How to give grid cell color in beforeLoadComplete function in JqxDataAdapter
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 11 years, 10 months ago.
  • Akshatha Raju
    I am working on Keyboard Navigation.My JSON value is from Controller is like floatvalue with stringdata (i.e){123.12_commentdata,12.90_abc,34.0_xyz,12.56_}.In beforeLoadComplete function i want to separate integer value and string value.If the separated data contain string value not equal to null then i change the color the of the that cell.Please give me the solution for this.
    var length = records.length;
    // loop through the records and display them in a Grid.
    for (var i = 0; i <length ; i++) {
    for(var j=0;j<colsofiaDataFieldArray.length;j++){
    var temp =records[i][colsofiaDataFieldArray[j].trim()];
    var pos1=temp.indexOf(“-“);
    var subs=temp.substring(0,pos1).trim();
    valueFloat=parseFloat(subs.substring(0,6)).toFixed(2);
    f (temp.substring(pos2+1)!=””&&  temp.substring(pos2+1)!=0) {
    //here i need to change the color of the cell
    records[i][colsofiaDataFieldArray[j].trim()]=valueFloat;
    retrun records;
    Hello Akshatha Raju,
    Cells cannot be coloured in the callback function beforeLoadComplete. To change the appearance of a cell, please use either cellsrenderer or cellclassname.
