Hi there,
I’m using jqxGrid integrated with a PHP script, via JSON. I’ve implemented the filters, orders, paging and have added the filterRow on a couple of columns.
Now my problem is that the filterRow contains only the values from the current page while I want it to show the value from the whole dataset. I understand this might not be possible due to the way the system is designed, however is there a way to preLoad a specific filterRow with a certain query ?
For instance I’ve a grid with a list of users, showing ID – Name – Permission – Email
I’ve the filterRow on the Permission column which will contains a specific list of strings (permission table in the dbase which doesn’t change much over time and it’s quite short). I would like the filterRow to show all possible permissions and not only the one showing on the first page of the grid so if I select one it will filter the whole dataset based on it.
I hope I’ve explained this clearly. If not ask away.
