jQuery UI Widgets Forums Chart Horizontal Column Graph Issue
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 10 months ago.
  • Horizontal Column Graph Issue #8475
    sushanth009
    Hello Peter,
    I tried populating a column graph with Horizontal orientation , the chart is rendering properly but some of the text is missing for some reason.. Can you have a look at it..
    var data = [
    "a":"[2001] 100 W Chestnut St 2001, , Chicago, IL 60610",
    "c":"54.43"
    "a":"[2710] 100 W Chestnut St 2710, , Chicago, IL 60610",
    "c":"47.81"
    "a":"[1703] 100 W Chestnut St 1703, , Chicago, IL 60610",
    "c":"35.64"
    "a":"[0302] 100 W Chestnut St 302, , Chicago, IL 60610",
    "c":"35.22"
    "a":"[2910] 100 W Chestnut St 2910, , Chicago, IL 60610",
    "c":"32.13"
    "a":"[2103] 100 W Chestnut St 2103, , Chicago, IL 60610",
    "c":"31.80"
    "a":"[0307] 100 W Chestnut St 307, , Chicago, IL 60610",
    "c":"29.21"
    "a":"[0704] 100 W Chestnut St 704, , Chicago, IL 60610",
    "c":"25.87"
    "a":"[1902] 100 W Chestnut St 1902, , Chicago, IL 60610",
    "c":"19.92"
    "a":"[1803] 100 W Chestnut St 1803, , Chicago, IL 60610",
    "c":"19.71"
    "a":"[2908] 100 W Chestnut St 2908, , Chicago, IL 60610",
    "c":"16.50"
    "a":"[1106] 100 W Chestnut St 1106, , Chicago, IL 60610",
    "c":"15.67"
    "a":"[2207] 100 W Chestnut St 2207, , Chicago, IL 60610",
    "c":"15.63"
    "a":"[2201] 100 W Chestnut St 2201, , Chicago, IL 60610",
    "c":"15.20"
    "a":"[2204] 100 W Chestnut St 2204, , Chicago, IL 60610",
    "c":"14.30"
    "a":"[3010] 100 W Chestnut St 3010, , Chicago, IL 60610",
    "c":"13.65"
    "a":"[1402] 100 W Chestnut St 1402, , Chicago, IL 60610",
    "c":"13.33"
    "a":"[2706] 100 W Chestnut St 2706, , Chicago, IL 60610",
    "c":"13.03"
    "a":"[2807] 100 W Chestnut St 2807, , Chicago, IL 60610",
    "c":"10.18"
    "a":"[1806] 100 W Chestnut St 1806, , Chicago, IL 60610",
    "c":"8.05"
    "a":"[1602] 100 W Chestnut St 1602, , Chicago, IL 60610",
    "c":"7.24"
    "a":"[1102] 100 W Chestnut St 1102, , Chicago, IL 60610",
    "c":"6.55"
    "a":"[1207] 100 W Chestnut St 1207, , Chicago, IL 60610",
    "c":"4.10"
    "a":"[2010] 100 W Chestnut St 2010, , Chicago, IL 60610",
    "c":"2.30"
    This is the json data..
     var source = {
    datafields: [{ name: 'a' }, { name: 'c'}],
    localdata: data,
    datatype: 'json'
    var settings = {
    title: "Service Locations",
    showLegend: true,
    enableAnimations: true,
    padding: { left: 15, top: 5, right: 15, bottom: 5 },
    categoryAxis: {
    dataField: 'a',
    showGridLines: true,
    text: 'Service Locations',
    textRotationAngle: 90,
    flip: false
    colorScheme: 'scheme01',
    seriesGroups:
    type: 'column',
    orientation: 'horizontal',
    columnsGapPercent: 100,
    toolTipFormatSettings: { thousandsSeparator: ',' },
    valueAxis:
    flip: true,
    unitInterval: 10,
    displayValueAxis: true,
    minValue: minValue,
    maxVaue: maxValue + 1,
    description: comp
    $('#charts').jqxChart(settings);
    Your help is really appreciated..
    Sushanth
    Horizontal Column Graph Issue #8533
    Hi sushanth009,
    Thank you for the feedback! Your feedback is greatly appreciated!
    We will investigate the reported behavior.
    Best Wishes,
