jQuery UI Widgets Forums General Discussions grid validation not work
This topic contains 3 replies, has 2 voices, and was last updated by  Hristo 7 years, 7 months ago.
  • grid validation not work #97907
    IvanNie
    Hello Jqwidgets developer,
    I face a matter problem about grid cell validation together with grid cell properties, may be my question not clear, i describe it below:
    1. in my grid i have a grid cell have not null validaton,
    2. next to grid below cell is a not editable cell, and other grid cell is editable,
    3. when i edit this grid, the not null grid cell get focus, note: it has a not null validation,
    4. if i click other cell, which cell can be editable, expect not null validation works,
    5. but if i first double click not editable cell, then i click other editable cell, the not null validation not work, and this not null validation lose focus, other editable cell get focus,
    i search from forums some times, but not found any answer, could you help me with this problem? i hope you can give some suggestion about this problem? and reply me if you are free,
    Thanks.
    grid validation not work #97913
    Hello IvanNie,
    I would like to suggest you look at this topic, it could be useful, too:
    https://www.jqwidgets.com/community/topic/grid-filter-does-not-contain-issue/
    Also, it will be better if it is possible to provide us a simple example that demonstrates this issue (with a few records).
    grid validation not work #97958
    IvanNie
    Hello Hristo,
    I am sorry for that, this is my problem, after i debug, it is nothing to do with jqweights, the reason is a dom element add so much event, which i hope the sequence of events triggered as i expected, but it is pity the sequence is not as i expect, so this is the reason, i am soory for that. thank you for your reply. could i close this problem?
    grid validation not work #97960
    Hello IvanNie,
    Thank you for your response.
