jQuery UI Widgets Forums Navigation Tree Drag and drop problem
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 2 months ago.
  • Drag and drop problem #18021
    shashi
    I have two trees. I will drag one child item from source tree to dest tree. My problem is when ever i drop the dragged item it should be added to the parent Node which matches with the Parent Node of the source tree. It should not be added to dest tree and parent item or to any other parent item.
    How should I achieve it, Please help me
    Drag and drop problem #18024
    Hi shashi,
    The built-in Drag and Drop works as demonstrated in our sample. It cannot be modified.
