jQuery UI Widgets Forums Grid problem
This topic contains 18 replies, has 2 voices, and was last updated by  nico86 10 years, 2 months ago.
Viewing 15 posts - 1 through 15 (of 19 total)
    problem Posts
  • problem #70704
    nico86
    Hi
    I think there is a compatibilty probleme with jqxgrid (dropdownlist ?) and internet explorer 8 .
    This problem also exists in your demos. For exemple cell cellediting.htm
    bug1
    problem #70754
    Hi nico86,
    We tested our online demo (version 3.8.0) cellediting.htm with Internet Explorer 8. There were no errors thrown and the demonstrated functionality works fine. Please make sure you have downloaded the latest version and if necessary, re-download it and add the jQWidgets files to your project again.
    problem #70773
    nico86
    I have redownload the widget, and same problem :
    for example , with the cellediting demo feile the problem appears when i double-click on a cell of the column product
    thanks.
    problem #70783
    Hi nico86,
    Do you experience this issue with the online demo?
    problem #70790
    nico86
    i can’t tell you because on my company on my workstation I have no internet…And on other post i have IE11…but i I am obliged to work with IE8.
    and you have you test when you click on the cell of the column product ?
    thanks
    problem #70818
    Hi nico86,
    We were able to reproduce this issue but with Internet Explorer 7, not 8. The error states: “Invalid property value.” and is related to the unsupported use of the inherit CSS keyword. It is, however, supported in Internet Explorer 8 and the issue should not occur there.
    problem #70933
    nico86
    very strange, is it possible is due to IE setting ? but which setting ?
    problem #70955
    Hi nico86,
    This may happen if your browser is in Quirks mode.
    problem #70967
    nico86
    I have tried jqxdropdownlist.js instead of from 3.7.1 into 3.8 and all work fine, what is the difference. ?
    thanks.
    problem #70980
    nico86
    all demo from jqxdropdownlist have the same problem, i dont know if IE8 is in quirks mode but how to fix it ?
    problem #70986
    Hi nico86,
    This issue occurs only in IE7 and probably IE8 in Quirks mode. You can read this Stack Overflow topic to learn how to switch this browser mode off: http://stackoverflow.com/questions/20594749/how-to-disable-quirk-mode. The issue itself will be fixed in version 3.8.1 of jQWidgets.
    problem #70994
    nico86
    thanks, i succeed in turn off this option. it was “compatibility mode for intranet sites”
    problem #71238
    nico86
    Sometimes, when i navigate into my large grid, I have a new problem with IE 8 (with IE8 borwser mode and IE document mode)
    Some columns are not displayed and i have a javascript problem (see screen below)
    Does parentNode use into jqxgrid is compatible with IE8 ?
    Capture
    thanks
    Nicolas.
    problem #71249
    Hi Nicolas,
    Do you experience this issue with any of the grid demos? If not, could you, please, provide us with a JSFiddle we can test to reproduce it?
    problem #71279
    nico86
    I need to make one example.
    I have used your demo file cellediting.html, and i just add four columns (a,b,c,d,e)
    when I scroll to the right, missing columns (availaible , quantity , price , date)
    Capture1
    then when i scroll to left the colums a, b, c, d, e have become blank.
    Capture2
    Thanks.
        <title id='Description'>In order to enter in edit mode, select a grid cell and start typing, "Click" or press the "F2" key. You
        can also navigate through the cells using the keyboard arrows or with the "Tab" and "Shift + Tab" key combinations. To cancel the cell editing, press the "Esc" key. To save
        the changes press the "Enter" key or select another Grid cell. Pressing the 'Space' key when a checkbox cell is selected will toggle the check state.</title>
        <script type="text/javascript" src="../../jqwidgets/jqxnumberinput.js"></script>
        <script type="text/javascript" src="../../jqwidgets/globalization/globalize.js"></script>
                var data = generatedata(200);
                    localdata: data,
                    datatype: "array",
                        // and with parameter false if the synchronization failder.
                        commit(true);
                    datafields:
                        { name: 'a', type: 'string' },
                        { name: 'b', type: 'string' },
                        { name: 'c', type: 'string' },
                        { name: 'd', type: 'string' },
                        { name: 'e', type: 'string' },
                        { name: 'date', type: 'date' }
                // initialize jqxGrid
                $("#jqxgrid").jqxGrid(
                    width: 850,
                    enabletooltips: true,
                      { text: 'a', columntype: 'textbox', datafield: 'a', width: 120 },
                      { text: 'b', columntype: 'textbox', datafield: 'b', width: 120 },
                      { text: 'c', columntype: 'textbox', datafield: 'c', width: 120 },
                      { text: 'd', columntype: 'textbox', datafield: 'd', width: 120 },
                      { text: 'e', columntype: 'textbox', datafield: 'e', width: 120 },
                      { text: 'First Name', columntype: 'textbox', datafield: 'firstname', width: 120 },
                      { text: 'Last Name', datafield: 'lastname', columntype: 'textbox', width: 120 },
                      { text: 'Product', columntype: 'dropdownlist', datafield: 'productname', width: 195 },
                      { text: 'Available', datafield: 'available', columntype: 'checkbox', width: 67 },
                          text: 'Ship Date', datafield: 'date', columntype: 'datetimeinput', width: 110, align: 'right', cellsalign: 'right', cellsformat: 'd',
                      validation: function (cell, value) {
                              if (value == "")
                                 return true;
                              var year = value.getFullYear();
                              if (year >= 2015) {
                                  return { result: false, message: "Ship Date should be before 1/1/2015" };
                              return true;
                          text: 'Quantity', datafield: 'quantity', width: 70, align: 'right', cellsalign: 'right', columntype: 'numberinput',
                              if (value < 0 || value > 150) {
                                  return { result: false, message: "Quantity should be in the 0-150 interval" };
                              return true;
                              editor.jqxNumberInput({ decimalDigits: 0, digits: 3 });
                      { text: 'Price', datafield: 'price', align: 'right', cellsalign: 'right', cellsformat: 'c2', columntype: 'numberinput',
                              if (value < 0 || value > 15) {
                                  return { result: false, message: "Price should be in the 0-15 interval" };
                              return true;
                              editor.jqxNumberInput({ digits: 3 });
                // events
                $("#jqxgrid").on('cellbeginedit', function (event) {
                    var args = event.args;
                    $("#cellbegineditevent").text("Event Type: cellbeginedit, Column: " + args.datafield + ", Row: " + (1 + args.rowindex) + ", Value: " + args.value);
                    $("#cellendeditevent").text("Event Type: cellendedit, Column: " + args.datafield + ", Row: " + (1 + args.rowindex) + ", Value: " + args.value);
        <div id='jqxWidget'>
            <div id="jqxgrid"></div>
            <div style="font-size: 12px; font-family: Verdana, Geneva, 'DejaVu Sans', sans-serif; margin-top: 30px;">
                <div id="cellbegineditevent"></div>
                <div style="margin-top: 10px;" id="cellendeditevent"></div>
