jQuery UI Widgets Forums Lists ComboBox combo box
This topic contains 3 replies, has 2 voices, and was last updated by  ivailo 9 years, 5 months ago.
    combo box Posts
  • combo box #79627
    nagaveni
    I have implemented the jqxgrid containing combo box column.I am tabbing through the grid cells for
    editing, when tabbing reaches combo box cell I am pressing up and down keys on the keyboard.But the
    combo box is not opening.
    Is there any option to open or display combo box items when up and down keys are pressed?
    please give me a solution.
    Regards
    Nagaveni
    combo box #79640
    ivailo
    Hi nagaveni,
    You can try this approach : editing of grid on cellselect.
    Ivailo Ivanov
    combo box #79643
    nagaveni
    Hi Ivailo Ivanov,
    The issue of “Not opening the combo box, when pressing down arrow key on keyboard” is also there in
    the above sample you provided.
    it is opening when clicked on “Alt+down arrow key”,But I want the combo box
    should be opened when clicked on “down arrow key” while tabbing through.
    Regards
    Nagaveni
    combo box #79655
    ivailo
    Hi nagaveni,
    Unfortunately opening only with down arrow key is not supported.
    Ivailo Ivanov
