jQuery UI Widgets Forums General Discussions Navigation Tree click enable on particular nodes
This topic contains 7 replies, has 2 voices, and was last updated by  Dimitar 11 years, 5 months ago.
  • click enable on particular nodes #50036
    mallepaddi
    Hi
    I am generating tree with 3 levels, let’s say Country -> State -> Place
    When we need to make an backend action only when user clicks “Place” node, how to find it ?
    Nothing should happen clicking on Country and Sate .
    click enable on particular nodes #50092
    Hello mallepaddi,
    Here is an example, which alerts a message only when the item level is 1 (levels are zero-based numbered). In your case, you will need to check for the second level.
        <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script>
        <script type="text/javascript" src="../../jqwidgets/jqxexpander.js"></script>
                // Create jqxExpander
                $('#jqxExpander').jqxExpander({ showArrow: false, toggleMode: 'none', width: '300px', height: '370px' });
                // Create jqxTree
                var source = [
                    icon: "../../images/mailIcon.png", label: "Mail", expanded: true, items: [
                      { icon: "../../images/calendarIcon.png", label: "Calendar" },
                      { icon: "../../images/contactsIcon.png", label: "Contacts", selected: true }
                    icon: "../../images/folder.png", label: "Inbox", expanded: true, items: [
                     { icon: "../../images/folder.png", label: "Admin" },
                     { icon: "../../images/folder.png", label: "Corporate" },
                     { icon: "../../images/folder.png", label: "Finance" },
                     { icon: "../../images/folder.png", label: "Other" },
                { icon: "../../images/recycle.png", label: "Deleted Items" },
                { icon: "../../images/notesIcon.png", label: "Notes" },
                { iconsize: 14, icon: "../../images/settings.png", label: "Settings" },
                { icon: "../../images/favorites.png", label: "Favorites" }
                $('#jqxTree').jqxTree({ source: source, width: '100%', height: '100%' });
                $('#jqxTree').jqxTree('selectItem', null);
                $('#jqxTree').on('select', function (event) {
                    var args = event.args;
                    var item = $('#jqxTree').jqxTree('getItem', args.element);
                    var label = item.label;
                    if (item.level == 1) {
                        alert("Clicked a second-level item!");
        <div id='jqxWidget'>
            <div id='jqxExpander'>
                <div>
                    Folders
                    <div style="border: none;" id='jqxTree'>
    click enable on particular nodes #50100
    mallepaddi
    Hi
    many thanks.
    perfect it works.
    But please help me where i can find more documentation like item.level and other possible attributes on “item” and “element” ?
    click enable on particular nodes #50102
    Hi mallepaddi,
    You can find all available information about the jqxTree methods and properties in the API Documentation. Here is an excerpt from there about getItem:
    Gets the selected tree item.
    Item Fields
    label – gets item’s label.
    value – gets the item’s value.
    disabled – gets whether the item is enabled/disabled.
    checked – gets whether the item is checked/unchecked.
    element – gets the item’s LI tag.
    parentElement – gets the item’s parent LI tag.
    isExpanded – gets whether the item is expanded or collapsed.
    selected – gets whether the item is selected or not.
    click enable on particular nodes #50103
    mallepaddi
    Many thanks.
    But those mentioned properties are not found in API section, like item.parentElement ?
    click enable on particular nodes #50104
    mallepaddi
    sorry, found them.
    click enable on particular nodes #50105
    mallepaddi
    Hi
    How about “event”, like event.args.element ?
    click enable on particular nodes #50131
    Hi mallepaddi,
    Just expand any of the jqxTree events (e.g. select) in the API Documentation and you will see their event arguments.
