jQuery UI Widgets Forums TreeGrid CheckBoxes and ExpandAll Problem
This topic contains 3 replies, has 3 voices, and was last updated by  Eaton 8 years, 5 months ago.
  • CheckBoxes and ExpandAll Problem #78095
    Klaus H
    I have stumbled upon a strange behaviour. I updated the jqxwidget version in an application from version 3.6 to the current version. I use a jqxTreeGrid in said application that uses checkboxes for selection and after loading the data, I had to expand all the rows. In the 3.6 version I used a function found in the forum (traverseTreeGrid) to do so, in the new version you have provided an expandAll function.
    Changing from traverseTreeGrid to expandAll now causes a strange behaviour I did not expect – all checkboxes from second level on have tha black square in them like in a three state selection. In the treegrid there is no hierarchical selection enabled and by clicking in the checkboxes, I only can check and uncheck after that.
    You can check this behaviour in your provided fiddle example with checkboxes:
    http://jsfiddle.net/jqwidgets/fhbLa/
    and change the ready function of the treegrid to: $(“#treeGrid”).jqxTreeGrid(‘expandAll’);
    Best Regards
    Klaus
    CheckBoxes and ExpandAll Problem #78147
    Hi Klaus,
    There actually IS hierarchical checkbox selection in the TreeGrid. See: http://jsfiddle.net/jqwidgets/mbLb4n7o/. Anyway, the observed behavior should be improved in future releases. For now, you can check/uncheck via checkRow and uncheckRow method calls in that specific situation or continue using the traverse function.
    CheckBoxes and ExpandAll Problem #78184
    Klaus H
    Hello Peter,
    thank you for the feedback. 🙂
    Best Regards
    Klaus
    CheckBoxes and ExpandAll Problem #89698
    Eaton
    Any feedback on this issue yet?
