jQuery UI Widgets Forums Grid Changing "NumberInput" column properties after grid rendering
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 3 months ago.
  • andy8
    Hello all,
    Is it possible to change properties of jqxNumberInput objects after grid was rendered. Let’s say we add a custom jqxNumberInput column like that:
    columns: [{
        text: 'Factors',
        datafield: 'factors',
        width: 80,
        columntype: 'custom',
        createeditor: function (row, cellvalue, editor, cellText, width, height) {
            editor.jqxNumberInput({
                decimalDigits: 4,
                inputMode: 'simple',
                max: 0,
                min: 1,
                value: 0,
                spinButtons: true,
                spinMode: 'advanced'
    Then, after the grid has been rendered, I wanted to change min-max limits programmatically. Is it doable?
    Hi andy8,
    initeditor is called each time the editor is opened. If you want to dynamically change editor settings, that’s the callback function which you should use.
    andy8
    Thanks – do you mean something like this?
    columns: [{
        text: 'Factors',
        width: 80,
                decimalDigits: 4,
                max: 0,
                min: 1,
                value: 0,
                spinButtons: true,
        initeditor: function (row, cellvalue, editor, celltext, pressedkey) {
                    decimal: parseFloat(cellvalue),
                    max: GlobalMin,
                	min: GlobalMax,
    and define vars GlobalMin and GlobalMax globally?
    Hi andy8,
    It is your own decision how to implement “initeditor”. I mean that, if you want to update dynamically an editor, then you should use “initeditor”.
