jQuery UI Widgets Forums Grid Adding jqWidgets V10 to a project
This topic contains 4 replies, has 2 voices, and was last updated by  pedro10 4 years, 9 months ago.
  • Adding jqWidgets V10 to a project #112679
    pedro10
    I use NSB AppStudio to create apps.
    I’m trying to add version 10 of jqWidgets to my project and i’m having trouble doing so. With an older version i used (9.1.4), i just added the jqwidgets folder (from inside the downloaded 9.1.4) to the my project and the controls ran fine.
    However, with the latest version (10.0.2), i added the same folder but get an error when trying to run code used for jqxGrid.
    The error is,
    jqxgrid.js
    Uncaught ReferenceError: that is not defined.
    line 8 column 260013
    Are there other files/folders that i need to add to my project?
    Adding jqWidgets V10 to a project #112685
    admin
    Hi pedro10,
    Can you post the code of this error?
    https://www.jqwidgets.com/
    Adding jqWidgets V10 to a project #112690
    pedro10
    The code i used for this is below. The app consists of only a button and jqxGrid.
    Button1.onclick = function()
         gedata = [];
         //get grid data
         for     (i = (0); i  <= 100; i ++)
              row = [];
              for     (j = (0); j  <= 10; j ++)
                   row["col" + j] = i;
              gedata[i] = row;
         //get data field array and columns to display
         datafieldsArray = [];
         columnsArray = [];
         gridcolsindex = 0;
         for     (k = (0); k  <= 10; k ++)
                datafieldsArray[gridcolsindex] = {name: "col" + k , type: "text"};
                columnsArray[gridcolsindex] = {text: "Col" + k, datafield: "col" + k, cellsalign: 'center', align: 'center', width: "10%"};
                gridcolsindex = gridcolsindex + 1;
             localdata: gedata,
             datafields: datafieldsArray,
             datatype: "array"
         $("#Grid1").jqxGrid({
            //width: 800,
            theme: 'energyblue',
            //columnsheight: 25,
            rowsheight: 30,
            source: adapter,
            sortable: True,
            //selectionmode: 'singlecell',
            columns: columnsArray
    Adding jqWidgets V10 to a project #112695
    admin
    Hi pedro,
    I prepared a sample based on this code and posted it here: http://jsfiddle.net/8fr7pt9c/
    Adding jqWidgets V10 to a project #112713
    pedro10
    Thanks Peter
