This topic contains 2 replies, has 2 voices, and was last updated by  74bit 9 years, 5 months ago.
  • z-index of scrollbar #81395
    74bit
    I have a jqxDocking with some containers which might have scrollbars.
    When I open a jqxWindow in front of those, the vertical scrollbars of the containers is still visible (z-index higher than the elements in the windows)
    I can’t provide the source, but I have a screenshot, please see http://a31i.imgup.net/screen0ea9.png
    Thank you for your help,
    74BIT
    z-index of scrollbar #81403
    Hello 74BIT,
    Please try increasing the zIndex property of your window as a solution.
    z-index of scrollbar #81405
    74bit
    I already did this before did not help.
    But I found the solution: you have to add an z-index to the div which contains the content of the docking-element.
    Thanks anyway
