jQuery UI Widgets Forums Chart X-axis labeling for Chart Column are not correctly labeled
This topic contains 3 replies, has 2 voices, and was last updated by  petite_moi 13 years ago.
  • petite_moi
    petite_moi
    I am trying to recreate the chart column series. However, the x-axis is skipping every 3rd label.
    For example, it would be AB then GH then MN then RS. The label is wrong for the column, but the columns are correct in that it is shown the AB series, then CD series, and so forth.
    I don’t know why it is doing that. Any help would be great. Thanks in advance.
    My sample text file:
    AB,4,22
    CD,174,233
    EF,11,7
    GH,2,4
    IJ,23,28
    KL,120,134
    MN,39,53
    NO,42,38
    PQ,1,1
    RS,2,6
    TU,40,50
    VW,163,202
    XY,0,1
    AZ,50,52
    WE,369,498
    GC,4,2
    MA,109,109
    NA,542,767
    NE,41,50
    NF,0,0
    PO,3,0
    NT,13,15
    TT,11,15
    SS,9,0
    RR,1,3
    SS,16,33
    EE,0,0
    AA,14,31
    Javascript:
    datatype: “csv”,
    { name: ‘Organization’ },
    { name: ‘Q1’ },
    { name: ‘Q2’ }
    url: ‘sampledata1.txt’
    var dataAdapter = new $.jqx.dataAdapter(source, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert(‘Error loading “‘ + source.url + ‘” : ‘ + error); } });
    // prepare jqxChart settings
    var settings = {
    title: “cHART EXAMPLE”,
    description: “”,
    showLegend: true,
    enableAnimations: true,
    categoryAxis:
    dataField: ‘Organization’,
    showGridLines: true
    colorScheme: ‘scheme01′,
    seriesGroups:
    type: ‘column’,
    columnsGapPercent: 50,
    valueAxis:
    unitInterval: 250,
    displayValueAxis: true,
    description: ‘User Count’
    series: [
    { dataField: ‘Q1’, displayText: ‘Q1 per Capita’},
    { dataField: ‘Q2’, displayText: ‘Q2 per Capita’ }
    // setup the chart
    $(‘#jqxChart’).jqxChart(settings);
    petite_moi
    I continue to further mess with this chart. If the setting for the
    is
    it would only show 14 column series. Once there are more than 14 records, it will start to label every other series. Does anyone know why there is a limit of number of columns??
    Hi petite_moi,
    You need to set the ‘unitInterval’ in the categoryAxis
    Here’s a working sample:
    <title id='Description'>jqxChart Column Series Example</title>
    <script type="text/javascript" src="../../scripts/jquery-1.7.2.min.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxchart.js"></script>
    datatype: 'csv',
    { name: 'Organization' },
    { name: 'Q1' },
    { name: 'Q2' }
    url: 'sampledata.txt'
    async: false,
    autoBind: true,
    alert("error");
    var settings = {
    title: 'Chart Example',
    description: '',
    showLegend: true,
    categoryAxis:
    dataField: 'Organization',
    unitInterval: 1,
    showGridLines: true
    colorScheme: 'scheme01',
    seriesGroups:
    type: 'column',
    valueAxis:
    unitInterval: 250,
    description: 'User Count'
    series: [
    { dataField: 'Q1', displayText: 'Q1 per Capita' },
    { dataField: 'Q2', displayText: 'Q2 per Capita' }
    // setup the chart
    $("#jqxChart").jqxChart(settings);
    <div style='height: 600px; width: 682px;'>
    <div id='host' style="margin: 0 auto; width:680px; height:400px;">
    <div id='jqxChart' style="width:680px; height:400px; position: relative; left: 0px; top: 0px;">
    Hope this helps you.
    Best Wishes,
    petite_moi
    Peter,
    This works great!! Thank you for the quick response. I am evaluating this widget for a project. If this continue to work out, the company will have to purchase the enterprise license. Thanks again.
