jQuery UI Widgets Forums Navigation Menu, Context Menu Wrong style for hovered with
This topic contains 6 replies, has 3 voices, and was last updated by  Peter Stoev 13 years, 1 month ago.
  • Wrong style for hovered with #1274
    lukes
    It looks like jqxMenu add wrong style to LI that contains a link. The link is moved down compering to other menu elements.
    The style of LI with a link is: float: left; padding-top: 8px; padding-bottom: 9px;
    The style of LI without a link: float: left; padding-top: 6px; padding-bottom: 7px;
    Wrong style for hovered with #1279
    Hi lukes,
    The jqxMenu applies CSS styles to the LI elements and anchor tags, if any. The .jqx-menu-item class is applied to the sub menu items and the .jqx-menu-item-top class is applied to the top-level menu items. Each of these classes also define appropriate styles for the anchor tags, for example: jqx-menu-item a:hover, etc. The CSS files are included in the installation and you can find them in the jqwidgets/styles folder.
    Thank you for the feedback. We appreciate it.
    Wrong style for hovered with #1284
    lukes
    Well… i would change CSS file, but the padding is added as a “style” attribute, which looks like it is jqwidget script work.
    Wrong style for hovered with #1285
    lukes
    Unless, it is not a bug, but this is how it supposed to work.
    Wrong style for hovered with #1305
    Hi lukes,
    jqxMenu has an option to try to vertically align the top-level menu items depending on their content by adding top and bottom padding. You can disable this built-in feature by setting the autoSizeMainItems property to false. Hope this information helps you.
    Wrong style for hovered with #3395
    jack78
    Since this thread was, at some point, related to the .jqx-menu-item class in jqx.base.css, I would like to mention that the current CSS file (line 882) applies to all visited links and not only the ones under .jqx-menu-item like it should.
    Current line : .jqx-menu-item a:link, a:visited
    Just so you know…
    Jack
    Wrong style for hovered with #3396
    Hi Jack,
    Thanks for the feedback. The reported issue is known and will be resolved in the next release which will come with the new Theme Builder.
