jQuery UI Widgets Forums General Discussions Layouts Splitter What is wrong with my splitter?
This topic contains 4 replies, has 2 voices, and was last updated by  hcccs 10 years, 7 months ago.
  • What is wrong with my splitter? #65094
    hcccs
    I have copied an example splitter and altered it slightly but then it doesn’t work and I can’t spot the error.
    <DOCTYPE html>
    <html lang=”en”>
    <meta name=”keywords” content=”jQuery Splitter, Splitter Widget, Splitter, jqxSplitter” />
    <link type=”text/css” rel=”stylesheet” href=”/jqwidgets/styles/jqx.base.css” />
    <link type=”text/css” rel=”stylesheet” href=”/jqwidgets/styles/jqx.summer.css” />
    <script type=”text/javascript” src=”http://code.jquery.com/jquery-1.11.0.min.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxsplitter.js”></script>
    $(‘#mainSplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, orientation: ‘horizontal’, panels: [{size: ‘15%’}, {size: ‘70%’}, {size: ‘15%’}] });
    $(‘#midSplitter’).jqxSplitter({ width: ‘100%’, height: ‘70%’, orientation: ‘vertical’, panels: [{size: ‘15%’}, {size: ‘70%’}, {size: ‘15%’}] });
    <body>
    <div id=”mainSplitter”>
    <div>
    Top menu
    <div>
    Mid split
    <div>
    Bottom panel
    What is wrong with my splitter? #65133
    Nadezhda
    Hello hcccs,
    You are missed to add “midSplitter” id and the above HTML Structure is invalid. You need to use nested jqxSplitter for the second id selector.
    Please, find the following html elements within the body of the html document. If this suggestion does not help you fix the issue, please, provide us with more information.
        <div id="mainSplitter">
            <div>
                Top menu
            <div>
                <div id="midSplitter">
                    <div>
                        Mid split
                    <div>
                        Bottom panel
    Nadezhda
    What is wrong with my splitter? #65222
    hcccs
    Ok, I have taken a step backwards and cut down the code to its bare bones just to make something work. I don’t seem to have much luck in spite of my thirty years as a programmer. What am I doing so wrong?
    <html lang=”en”>
    <script type=”text/javascript” src=”/js/jquery-2.1.3.js”></script>
    $(‘#hor1Splitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, orientation: ‘horizontal’, panels: [{size: ‘10%’}, {size: ‘90%’}}] });
    <body>
    <div id=”hor1Splitter”>
    <div>
    Top
    <div>
    Middle
    What is wrong with my splitter? #65240
    Nadezhda
    Hi hcccs,
    Here is an example which shows how to use jqxSplitter. Please, note that reference to jquery file is different. I would also suggest you to use the most recent version of jQWidgets which is 3.6.0.
        <title>Horizontal Splitter </title>
        <script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script>
        <style type="text/css">
            html, body {
                height: 100%;
                width: 100%;
                margin: 0px;
                padding: 0px;
                overflow: hidden;
        </style>
                $('#hor1Splitter').jqxSplitter({ width: "100%", height: "100%", orientation: 'horizontal', panels: [{ size: '10%' }, { size: '90%' }] });
        <div id="hor1Splitter">
            <div>Top</div>
            <div>Middle</div>
    Nadezhda
    What is wrong with my splitter? #65282
    hcccs
    I got it working now, at last.
