jQuery UI Widgets Forums Grid virtualmode problem with totalrecords
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 9 years, 3 months ago.
  • virtualmode problem with totalrecords #83706
    omargarro
    Hi, I have my grid like this:
    var source = {
    	type: 'post', url: 'inc/getOrders.php', datatype: "json", cache: false,
    	data: {},
    		{ name: 'OrderNbr', type: 'int'},{ name: 'TypeOf', type: 'string'},
    		{ name: 'State', type: 'string'},{ name: 'CustomerName', type: 'string'},
    		{ name: 'Active', type: 'string'}
    	root: 'Rows',
    	beforeprocessing: function(data) {
    		console.log(data[0].totalrecords);
    		source.totalrecords = data[0].totalrecords;
    		loadComplete: function () {},
    		loadError: function(xhr, status, error) {
    			console.log(xhr.responseText);
    $("#grid").jqxGrid( {
    	theme:'energyblue',
    	width: 800, height: 500,
    	columnsresize: true, sortable: true, enabletooltips: true,
    	pageable: true,  pagesize: 50, virtualmode: false, pagesizeoptions: ['20', '50', '100', '200'],
    	rendergridrows: function(obj) {
    		return obj.data;
    		{ text: 'Order', datafield: 'OrderNbr', width: 100},
    		{ text: 'Type', datafield: 'TypeOf', width: 200},
    		{ text: 'State', datafield: 'State', width: 200},
    		{ text: 'Customer', datafield: 'CustomerName', width: 200},
    		{ text: 'Active?', datafield: 'Active', width: 50}
    I tested the server side php script and it retrieves 198 records from DB.
    When virtualmode is true, the 198 records are retrieved and the paginator works as expected.
    When virtualmode is false, only the first 50 records are shown. Paginator shows: “1-50 of 50” (only 1 page with 50 records and pressing on ‘next page’ button does nothing)
    Although console.log(data[0].totalrecords) on beforeprocessing always outputs 198
    Thanks in adv
    Omar.
    virtualmode problem with totalrecords #83710
    Hi omargarro,
    totalrecords as demonstrated in our examples should be set when virtual mode is true. You can review the demos about Server paging.
    totalrecords should not be set when virtual mode is false.
