jQuery UI Widgets Forums Grid Virtual Data + paging with custom query and format
This topic contains 6 replies, has 3 voices, and was last updated by  tamaraOnt 12 years, 5 months ago.
  • bouyoul
    I am trying to use the jqxGrid control with paging, virtual data and a remote web service (that I do not control). However, I have the following restrictions:
    – My data is accessible via POST only: I need to send a somewhat large document as the query
    – The document does not stay constant between pages: It contains fields equivalent to pagenum and pagesize that need to be replaced for every page change
    – I need to set some HTTP headers in the query
    – The returned format is custom (i.e. neither XML or JSON): I need to transform the received data into a format supported by jqxGrid
    I am not really clear on how to achieve that. Are such restrictions workable?
    I was thinking of using a source and a dataAdapter but I am not sure how to indicate if the request is GET or POST or how to change headers or how to format the result. Is there a sample that would show how to achieve this? (Maybe one that shows how to use a completely custom ajax query i.e. $.ajax(…) for the fetching).
    (also is there documentation for jqx.dataAdapter?)
    Thanks for your help.
    B.
    Hi bouyoul,
    To learn how to use the jqx.dataAdapter, you can take a look at the help topics about the Grid and Chart about data binding – jquery-grid-datasources.htm, jquery-grid-php-server-side-processing.htm and jquery-chart-data-source.htm. jqx.dataAdapter supports binding to the following formats: tsv, csv, xml, json and data array. If your data is in a custom format, its better to make a standard ajax call and map your data to any of the supported data types and store it in an array. In virtual mode, the Grid expects the user to return an array of the visible rows in the ‘rendergridrows’ function(see the virtualdata.htm demo).
    bouyoul
    I saw that “virtualdata.htm” example. The problem with it is that it does not retrieve data asynchronously so that the rendergridrows can return the new data when it is called. However, if I have to make an asynchronous Ajax call to get my data, there is no way for rendergridrows to return anything at the time it is called. Is there a callback for the asynchronous case? If not, what should be done?
    B.
    Hi bouyoul,
    In your ajax’s success callback function, you can call the jqxGrid’s ‘updatebounddata’ function. This will ensure that the ‘rendergridrows’ function is called.
    jQwidgets Team
    tamaraOnt
    Sorry, I’, trying to do that, and I can’t. I have the following code:
    // generate sample data.
    var generatedata = function (startindex, endindex) {
    $.get("index.php", { startindex: startindex, endindex: endindex },function(result){
    var data = JSON.parse(result);
    return data;
    datatype: "array",
    localdata: {},
    totalrecords: 1000000
    // load virtual data.
    var data = generatedata(params.startindex, params.endindex);
    return data;
    $("#gridUser_1").jqxGrid(
    width: 670,
    theme: 'ui-start',
    virtualmode: true,
    { text: 'id', datafield: 'id', width: 100 },
    { text: 'idProfile', datafield: 'idProfile', width: 100 },
    { text: 'user', datafield: 'user', width: 120 },
    { text: 'password', datafield: 'password', width: 120 } ]
    <div id='contenidoTab1'>
    <div>
    <div id="gridUser">
    In the index.php, I have the following code, to simulate asking for data
    if (isset($_GET["startindex"])) {
    $result = Array();
    for($i = 0; $i < 10; ++$i){
    $row = Array();
    $row["id"] = $i;
    $row['user'] = 'tamara';
    $row['password'] = '12345';
    $row['idProfile'] = 1;
    $result[$i] = $row;
    echo json_encode((object)$result);
    I don’t know where I have to put the jqxGrid’s ‘updatebounddata’ function.
    If a show the content of the var ‘data’ in the rendergridrows after the call ‘generatedata’, says ‘undefined’.
    Hi tamaraOnt,
    We have online examples in the PHP section which demonstrate how to implement Server Paging. See here: serverpaging.htm.
    jQwidgets Team
    tamaraOnt
    Thanks a lot. I haven’t seen that example.
    It works now.
